Lg 55ln5700
  • sirentech
    • Apr 2021
    • 8
    Lg 55ln5700
    Of course, worked great for a period of time! Before it could run for any period of time and then will reboot itself. It did not want to shut itself off a few times, so I had to pull the power plug. Now lucky to get 1 minute of video then reboots.
    Drops out too fast to get some voltage readings.
    Have worked on many brands before but not familiar with this problem from LG. Thinking either the BG soldered main chip is in need of reseating or perhaps an Eprom failure. Main board failure or entirely wrong-LEDS??
    Main chip doesn't get hot enough to shut it down.
    Have not dug into the LED driver yet or tested the strips with an external tester.
    Thank you for any help you may offer.
  • bffargo
    2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
    by bffargo
    LG 60PB66550 NOV 2014
    PSU: EAY63168603
    PCB: EAX65359531 2013.11.01 Rev:1.0
    Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
    Symptom:
    While watching, just went black and started clicking relay every few seconds.
    Initial diagnosis:
    Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
    Deeper diagnosis:
    Pulling pins #1/#2 (Blue/Grey) from the connector housing...
    09-09-2022, 07:34 PM
  • sirentech
    LG 55LN5700 reboots
    by sirentech
    Have not...
    10-30-2022, 01:42 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • howardc64
    HP Inkjet printer main board bulging cap failure
    by howardc64
    Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
    https://h30434.www3.hp.com/t5/Printi...t/true#M997922
    02-03-2025, 09:50 PM
