Samsung UE40d550 main board bn94-05188v
  • GVITSERVICES
    • Sep 2019
    • 5
    Hi there. I have this tv and what happened is at follows.
    I had the rebooting problem with it and solved it by ordering the nand and replacing it. Atfer that it had no hdmi imput from any of them 1 through 4. Entered service mode factory reset same thing.
    In the end i entered service mode again and i had changed some setting (dont remember wich one) and the tv froze. Unplugged it and after plugging it back in if has no stand by light at all and is completly dead.
    Opened it up and found out that the processor heats up farly high (not sure if thats normal or not)
    The thing is that i dont know if i killed it by changing that setting or if it was just pure coincidence and the processor just died out.
    if i disconnect the main board i get backlight on the tv.
    My guess is that even if that setting changed it in any way it can't really make it that is dead dead. Can it?
    Dont ask me what setting i changed because i have no idea.
    Where is that service mode stored? In NAND or in some other part
  • lotas
    • Jan 2016
    • 4840
    • Russia
    Re: Samsung UE40d550 main board bn94-05188v
    If HDMI did not work, then it was necessary to reflash the EEPROM 24C256.
    And after installing a new NAND, you need to do it through the service menu "Factory reset".
    • lotas
      • Jan 2016
      • 4840
      • Russia
      Did you happen to run the command: "Micom Update"?
      • GVITSERVICES
        • Sep 2019
        • 5
        So the firmware was not good from the start then? Someone sent me the ic already programmed so i could not reprogrm it. I have a RT809 but not adaptor for it. Does this RT809 have an adapter for the ic of the tv?
        And is there any way to repair the motherboard? Or that change in setings fried the cpu.
        Thanks in advance
        • lotas
          • Jan 2016
          • 4840
          • Russia
          Rather, the Nand firmware was good (the TV stopped rebooting), if the HDMI ports do not work, then you need to reflash the eeprom 24C256, if you changed something and ran the command: "Micom Update" in the service menu and the TV turned into a brick, then you need to reprogram the Micom WT61P8 , if necessary, I can throw these firmware on 24С256 and WT61P8.
          • GVITSERVICES
            • Sep 2019
            • 5
            Too much of a hussle. Any1 who might have a motherboard for this one functional? Thanks
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
            • mrautom8
              Samsung TV UN75H6350AFXZC main board schematics?
              by mrautom8
              Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
              Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
              While relay is on, all voltage rails are present and steady (scoped) on main board.
              I love a good logic puzzle but getting lost without any schematics.
              No shorts on ANY capacitor main board.
              Thermal camera shows 3.3V inductor getting warm instantly but...
              10-19-2025, 06:32 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • Lee M.
              Samsung UN75RU8000FXZA bad main board?
              by Lee M.
              When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
              11-08-2023, 07:46 PM
