Samsung UN60J6200 No power up
  • bradcaps
    • Jan 2019
    • 22
    Greetings. I am taking a stab at my first TV repair. Its a 60" Samsung UN60J6200AF.
    Initial findings: Plug unit in, not turning anything
    on I find the 400v+ power supply to the LEDS is active.
    I am not familiar with TV power supply but i find it odd this is seemingly in the 'on' state.
    I do not get any reading across the 450v filter caps, but on the power diodes.
    I find two regulators on the tv. At this point i get 12v from center pin on one and a slightly fluctuating 1 v. on the 2nd regulator, and its cold.
    The two pinout cables from PS to the control board panel reads:
    (10 pin dual layer) top row i read- ground, 12v, 12v, 12v, 12v. bottom row- ground, 0, 12v, .9v, .3v
    The 4 wire cable to the panel are- 419v, 100v, 0, .8v
    The TV is too heavy for me to see if there is a picture that isnt backlit.
    I feel there is a bad regulator here but i would like feedback.
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung UN60J6200 No power up
    Is the TV turning on or turning on with no backlight?
    Testing for Samsung TVs
    Unplug the cable between the power supply and main board and plug the TV in. The backlights should come on. If they don't, you likely have bad backlights though bad backlights can damage the power supply. If backlights come on and TV doesn't turn on with the main board connected, the main board is suspect.
    2.Connect one ribbon cable at a time between the tcon and panel and see if one side displays a good image. If one side is bad, there is a panel fault on that side and all the boards (ps, main, tcon) are working.
    • dskall
      • Oct 2016
      • 2905
      • usa
      No indicator light on front coming on? I suspect you aren't getting any backlights.
      • bradcaps
        • Jan 2019
        • 22
        As far as I can tell I have no standby LED, no backlight, no nothing. Its dead. Can the regulator i pointed out as possibly bad be part of faulty standby power? Are schematics available?
        • bradcaps
          • Jan 2019
          • 22
          "Unplug the cable between the power supply and main board and plug the TV in."
          Still Nothing.
          • bradcaps
            • Jan 2019
            • 22
            i am reviewing the troubleshooting lcd tv pdf from sticky. It says "The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work,
            when this voltage is not present, there will be no any indicator light on the front panel)"
            This may confirm my suspicion. I am curious if the dead regulator i found is for the stand by power supply.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Need better pictures of boards, connectors and connector legends. Measure main cap across positive and neg. of cap.
              • bradcaps
                • Jan 2019
                • 22
                Thank you i added more images with legends. The last image shows a large On/Standby voltage test point which i measured 12v at that point after simply plugging the unit in. This perhaps demonstrates that the standby circuit is faulty. The third photo shows the regulator outputting the 1v. Im going to measure if any voltage is going in to it.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  What is part # on this regulator?
                  • bradcaps
                    • Jan 2019
                    • 22
                    FDPF3N50NZ
                    https://www.mouser.com/ProductDetail...yrciRkHg%3D%3D
                    Its a MOSFET not a regulator.
                    Pin 1 = 0v, pin 2 around 400mV, pin 3 a few millivolt.
                    Fault is perhaps more upstream.
                    I get 388v across each of the large 450v filter caps.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      What voltage do you get on the ps_on when you push the power button? That mosfet looks like it is for backlights. What voltage do you get on each grey wire picture 2 when you push power button?
                      • bradcaps
                        • Jan 2019
                        • 22
                        ps_on i read 4.46v with or without power button pressed.
                        two greys read 412v & 92v with or without power button pressed.
                        • bradcaps
                          • Jan 2019
                          • 22
                          According to this doc ps_on when off should be 0.2v, 3.3v when on. I am getting 4.3v A little concerning.
                          I am learning a microcontroller is used on these modern TVs to control analog ports such as like on an Arduino. This microcontroller controls the power LED. Either the microcontroller is faulty or its not getting power. We haven't found any anomalies with the power supply yet, 12v rail seems ok, therefore I suspect bad "main board" or microcontroller. I could diagnose it further if i had a schematic.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            I would try heating up controller and then try and power on. Or press on controller and try powering on.
                            • bradcaps
                              • Jan 2019
                              • 22
                              Good idea to check for cold joints. Will also try freeze spray.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Freeze spray won't help on BGA, which I assume you have with no mainboard pictures to go by.
                                • bradcaps
                                  • Jan 2019
                                  • 22
                                  No go with heat. The CPU is warm. The optical is lit. Poking with chopstick did nothing. I may have overlooked LED now i see it when moving power joystick. When power on I now see 5 blinks then nothing. I hold in power button LED flashes repeatingly.
                                  • bradcaps
                                    • Jan 2019
                                    • 22
                                    Here is board
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      So going back to post 5. You have no backlights. Then need to find out if you have image on screen with flashlight.
                                      • bradcaps
                                        • Jan 2019
                                        • 22
                                        After closer inspection I do see video.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • nathan425
                                          Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
                                          by nathan425
                                          Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
                                          Symptoms:
                                          • - no power
                                          • - no standby LED
                                          What I've done so far:
                                          - confirmed power supply is OK
                                          -- CN201 #4 showing 5.3V
                                          -- BD207 showing 5.3V
                                          -- removing the cable between the main board and the power board turns on the backlight.
                                          Pushing the power button on results in no change to any of the pins connecting the two boards.
                                          - function assembly appears to be NO GOOD
                                          -- there is no voltage showing on any of...
                                          11-01-2023, 06:34 PM
