Samsung TV UN55KS8000 dead - bad diode
  • bgilmer
    • Jul 2022
    • US
    I wanted to post about my successful repair of a dead Samsung TV.
    Model: UN55KS8000
    Power Supply Circuit Board Number: BN44-00878A
    Part required: SB5150 Schottky diode 150V 5A
    Symptoms:
    Powered TV on with remote control. Briefly (less than one second), saw video, then TV went dark.
    - Not working at all
    - No red LED
    - No standby power
    - Will not power on
    Attempted reboot:
    - Initially unplugged TV for about 20 seconds and plugged it back in (This has fixed this TV in the past when it was unresponsive.) Did not work this time.
    Repair procedure:
    - Removed five larger screws at the bottom of the TV
    - Used a plastic wedge tool to pop the back off of the TV. There are no hooks at the bottom of the TV, but there are hooks about every five inches, located about three inches in from the edge of the TV all the way around the sides and top. The edge of the hook faces the sides and up toward the top. You might be able to lift the cover from the bottom middle and have the clips pop loose. I just pried around the perimeter of the TV. One hint - watch out for the IR detector and power switch at the bottom of the TV. It can be damaged if you are not careful.
    - There are two circuit boards. One is the power supply board (located on the right as you view the TV from the back). The other is the TV processor board (located on the left as you view the TV from the back).
    - You can confirm that the power supply is bad by plugging in the TV and measuring the standby voltage (no need to turn the TV on) at the place indicated in the picture. There is a jumper on the board clearly labeled with voltages when in standby and on mode.
    - Disconnect the two ribbon cables from the power supply board by gently squeezing the sides while using a small screwdriver to back the plug out of the connector. Do not pull on the ribbon to remove the plug.
    - Remove the two screws holding down the power plug on the power supply board. Slide the board gently to the right and it should be free.
    I started by checking continuity of the fuse next to the power plug. It was fine. I then started to check all of the power diodes on the board based upon a repair video posted on YouTube. My thanks to 'Electronics Repair School' for the helpful post here --> https://www.youtube.com/watch?v=ZKsdGCkQKzo
    (I used an ohmmeter with a diode continuity function, but I think any ohmmeter would work.) The video was not for my model of Samsung, but I figured they probably use the same parts, and so these diodes may have a problem.
    As you can see from the picture, there are four larger Schottky diodes near the power transformer. Two measured as expected - open in one direction, .3 ohms in the other direction. However, the two closest to the heatsink both measured shorted in both directions. I snipped the leads on one side of both diodes so I could check them out of circuit. One checked normally, the other was shorted in both directions.
    I ordered replacement diodes off of eBay, replaced the bad diode, and put the power supply back into the chassis. I plugged it in and measured the standby voltage at the test jumper. It was normal. I reassembled the TV, and it worked normally.
    When reassembling the TV, be sure the infrared receiver/power switch is properly located before closing the case.
  • petehall347
    • Jan 2015
    • 4436
    Re: Samsung TV UN55KS8000 dead - bad diode
    if diodes are working parallel i change all of them and match vf . they really need to work together .. silly idea to run parallel to up the current really .be better with single bigger diodes . well that's how i see it anyway
    • bgilmer
      • Jul 2022
      • US
      Thank you Pete. Interestingly, they are not running in parallel, so just replaced the one. Very good point though. Appears to be a bridge arrangement.
      • B0r1s
        • Jun 2022
        • 21
        • Serbia
        Model: UN55KS8000
        Symptoms:
        - No red LED
        - No standby power
        - Will not power on
        Attempted reboot:
        Repair procedure:
        Hi, i have the same problem like you had, but on mine board, third diode was shorted, i replaced all four diodes, but after tv was on for 10 minutes, diode went short again. Same diode that was bad before
        Here is the thread with my problem - https://www.badcaps.net/forum/showthread.php?t=107589
        Is your tv still ok after you fixed it?
        • cedtronic
          • Feb 2023
          I Have the same samsung model TV and the symptoms was the same but after testing diodes, all 4 was good.
          after some time, I lifted the speakers module and the screen turn on!!! samsing build the tv with 2 little wire running between subwoofer magnet and a sharp rivet, the sheath was puctured by the rivet. a little bit of electrical tape and its worked !!! (sorry for ma poor english, I'm a french canadian !!!)
          • nomoresonys
            • 12266
            • U.S.
            Very good tip Cedtronic, have also run into this before, I understood your English very well.
            • EazyBone
              • Jun 2023
              • 1353
              • United states
              Thanks for this! Happened to me also. No light for tv appear dead. Disconnect main board and led would flash on off. The stby pin was fluctuating non stop. Mine were the far 2 right diodes. To sb5150 off a scrap board hooked it up and everything back to normal. Thought I'd give a shout out to this.
              Dm862c and the one next to it
              • Fontana
                BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
                by Fontana
                1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
                2. if
                12-18-2023, 05:45 AM
                09-07-2024, 05:50 AM
              • Dvsr
                On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                by Dvsr
                Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                After replacing the caps I started testing out the speaker. It seemed...
                09-10-2025, 10:20 AM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
                09-06-2024, 11:40 PM
