Westinghouse LCM22W2 Help (DAC-19M009)
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Westinghouse LCM22W2 Help (DAC-19M009)
    Originally posted by tloftus
    S1 -> S1A = 358 ohms
    S1 -> S1B = 356 ohms
    S2 -> S2A = 357 ohms
    S2 -> S2B = 357 ohms
    The next thing I did was your CFL test and what I found was interesting.. one at a time each of the bulbs displayed 2 seconds of light except for one, the one labeled CN2. It, by itself, did nothing.
    Your inverter transformers are likely good with your measurements.
    On CN2, you might have a poor ccfl wiring or solder. I believe I put sample pics of the above in the guide.
    --- begin sig file ---
    --- end sig file ---
    • Wrog
      • Oct 2009
      • 472
      #42
      Try using the set of CCFLs that failed in CN2 in one of the other connectors. That will tell you if it's the CCFLs themselves (or associated wiring) or the circuit that drives that CCFL. Also, what kind of noise? Is it a "buzz"? Could be arcing... try turning off the overhead lights (be careful, make sure you can still see what you are doing!!) and see if you can find the source.
      • PlainBill
        • Feb 2009
        • 7034
        It is most likely that the problem is with the wires to the CCFL, Wrog's idea will confirm it. If it IS the wiring, be very careful disassembling the panel. The flexible circuits are very fragile, especially where they attach to the glass panel.
        PlainBill
        • tloftus
          • Aug 2010
          • 9
          #44
          I think I've found the source -- it is a "buzzing" sound -- so while awaiting your replies I disassembled the backlight assembly further, the CFL on CN2 appears to be broken at its end. I plugged in the CFL so I could see it and turned the power supply on and that one did not light up and the "buzz" was coming from the broken end of the tube. I think you've helped me find my issue. I don't see any part numbers or anything to indicate what I should order for replacement parts. Do I have to buy the two bulb assembly? It looks like it might break down further and the individual bulbs might be able to be replaced? I have attached a photo of the full assembly as well as the broken end in case it helps anyone else.
          Thanks again,
          Tom
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            Good job. Excellent pics. I may use this thread as another example of poor wiring.
            ccflwarehouse.com and ccfldirect.com sell replacements that come in a variety of options (with housing, with cables, with silicon caps, without, etc).
            I believe a few members here have positive experiences with ccflwarehouse.com. I can't speak for either since I have never done business with them.
            PS. Good "Lamp Soldering Tutorial" with pictures at
            http://ccflwarehouse.com/lasotu.html
            • Wrog
              • Oct 2009
              • 472
              #46
              ccflwarehouse.com may have the entire assembly available, including bulbs, endcaps and wiring, but that's likely to be expensive ($30+). It could save you some headache though! If you are planning on keeping the monitor for an extended period of time, consider replacing all bulbs while you have it open... you should be able to get them for around $8 apiece. Here is their ebay auction for $8 apiece, with $4.95 combined shipping. Make sure you measure length and diameter carefully! It can't hurt to ask for endcaps as well, and even wiring if you don't have any handy (24AWG or 28AWG/3KV for high voltage side, 28AWG/300V for return side).
              • tloftus
                • Aug 2010
                • 9
                #47
                These appear to be right on 2.0mm in diameter and 480.0mm in length -- I'm not seeing anything in those measurements available.
                Edit: I'm just going to fill out their contact form and see what they've got -- they are in Omaha just down the road so should get here pretty quick.
                Thanks again everyone for the assistance!!
                Tom
                • Wrog
                  • Oct 2009
                  • 472
                  #48
                  Excellent -- if they don't work out, there's someone on eBay selling lamps specifically for this model (though they don't state what size they are). Good luck and post back with your success!
                  • tloftus
                    • Aug 2010
                    • 9
                    #49
                    Well I only broke 2 more bulbs but I got the bad one replaced and back in business! However the display seems very strange, dim, colors don't 'pop' like they used to -- I have a feeling I got the three sheets of plastic between the backlight and the LCD wrong. I can take it back apart and fix but I'm not sure how they came out.. can anyone provide any pointers as far as the order of the 3 sheets and which side is supposed to be out?
                    Thanks,
                    Tom
                    • alexanna
                      • Mar 2010
                      • 1346
                      #50
                      If this is simular to a LCD sceen
                      Rough side of thick glass down/white sheet between it and metal case
                      Two more pieces of plastic with smooth side down
                      Thicker piece of plastic, shiny silver side down, good luck
                      Al.
                      This one i have apart I think i kept them in corect order Let me know how it turns out.
                      • tloftus
                        • Aug 2010
                        • 9
                        #51
                        I followed your direction, it appears that the only one that matters is the 'prism' one -- I flipped it around (they have tabs so once you know one all the others have to be the correct orientation, but not necessarily the right order) and it looks 1000x better. Back to new!! Thanks everyone for your help.
                        Thanks,
                        Tom
                        • John Graham
                          • Jun 2024
                          • 16
                          I just got one of these boards in to repair. The main problem i am having is that it seems that he took it to someone else for repair first and they removed two caps from the board and never replaced them. I have no way of finding out the values of them and was wondering of someone could look on theirs that they are working on. Their locations are CE105 and CE109. Thank you
                          This is an old post and I'm hoping g you have the values you needed. But if you haven't: CE105 is 2.2mF 10V and CE109 is 220uF 25V.
                          Sincerely,
                          John Graham
                          • John Graham
                            • Jun 2024
                            • 16
                            Apparently, the Westinghouse LCM22W2 and the Acer AL2216W both use the same Delta DAC-19M009 (from the photographs on post #1 and my DAC-19M009 (see pic below). Correct me if I am wrong.
                            The Viewsonic (forget the model number) is different in that it has a auxiliary board for the audio.
                              ALIENWARE Area-51 i7-5820K Specification for Upgrade or Repair
                              This specification for the ALIENWARE Area-51 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 boardview and Area-51 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Area-51...
                              09-12-2024, 03:28 PM
                              ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                              This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                              ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                              This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                              Alienware Area 51m R2 Notebook Specification for Upgrade or Repair
                              This specification for the Alienware Area 51m R2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Area 51m R2 boardview and Area 51m R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                              09-07-2024, 02:00 AM
