LG OLED65CXPUA no video, no sound, just flash on side of screen
  • sut_boxer
    • May 2022
    Video linked below of screen issue.
    TV worked fine for 18 months, suddenly did not have video anymore.
    Cleaned all ribbons and connections with canned air, no change.
    Cleaned all ribbons and connections with rubbing alcohol, no change.
    Replaced T-Con board, no change.
    Inspected all the caps on the power board, none are bulging or out of place or broken.
    Wife is about to kill me for thinking I need to spend $200 on a new mainboard. Any ideas?
    https://youtube.com/shorts/UaCupH8yiUQ?feature=share
  • Diah
    • Feb 2013
    • 6435
    Re: LG OLED65CXPUA no video, no sound, just flash on side of screen
    well i hope you still alive...
    from yours video not easy to do judgment.. need more info / test.. for example this screen blinking did it reboot.. or remain so... if remain so did you noticed the Audio Optic Outport lit Red?
    you have on the Main boards 2 Micro switch, you can try one by one by press and keep press for 10 second while you plug the tv in wall..
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • Rozp
      70LE660U dark cloud or black screen with sound.
      by Rozp
      Hello Everyone,
      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
      08-29-2023, 05:25 PM
    • soeren
      A2442 - No sound over internal speakers and no video playback
      by soeren
      I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
      All happened after the battery ran out of power overall several days when I was on vacation.
      I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
      07-26-2024, 01:24 AM
    • ravi_1617
      HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
      by ravi_1617
      Hello to all ,
      I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
      Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
      on external VGA port image is perfect /normal , Attached image...
      07-25-2025, 12:07 AM
