CRT Replacement in Rear Projection TV
  • mpobanion
    • 23
    Hi, all
    Does anyone know from experience if a CRT can be replaced from another used TV set that works, a proper functioning blue projector of the same model? The latter set has a fungus. Can they be transfered?
    Thanks very much,
    Mike
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: CRT Replacement in Rear Projection TV
    just change the coolant.do all 3.mcm electronics has the coolant.you will have to take the tube off the lense and clean it well.there is a layer of crud on the face of the blue tube.
    • Wizard
      • Mar 2008
      • 2296
      And reconvergence. Will Must find the service manual to do this properly.
      Very specific tasks.
      Cheers, Wizard
      • echow2001
        Mac Mini M1 A2348 820-02091 rear IO port replacement p/n
        by echow2001
        need every single rear IO port socket replacement. some dumb kid destroyed every all of the sockets. before remove the socket from the board it would not boot but after remove it i see normal boot current consumption and chime. need to source the sockets for replacement. the HDMI, rj45, usbA audio combo appear to shared with macmini 2018 but the usb c is a different part
        part numbers in 2018 schematic not helpful on where to source, looks like its a custom part might just need to get a donor.
        RJ45-RCPT-X1037
        514-00083
        HDMI-RCPT-X1037...
        03-21-2024, 02:28 PM
      • waigy
        Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
        by waigy
        As the title.
        I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
        It looks basic enough inside with large components so I could do a full recap pretty easily.
        Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
        If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
        I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
        11-08-2024, 03:53 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
