Fixed dead Samsung UN50NU6900F
  • howardc64
    • Jun 2017
    • 626
    Looks like a common problem. Remote powers on power light with only high pitch squeal (and eventually cycling 3x) from the all-in-one board (main+PSU+tcon). No picture no sound. With the rear cover removed, squeal sounds like it came from main board section under the heat sink (which doesn't make sense of course but maybe just due to all-in-one board design) Here is a sound sample, turn up volume to hear.
    https://youtube.com/shorts/oc5PQiZkQ8g?feature=share
    2 PSU section caps were bulging. Replaced both of these fixed the TV. Spec is 470uF 25V and only reads 120uF after removal.
    Here is how to open the back. See the pic showing the plastic fingers on the rear plate clipping onto the metal frame+wire. Do both sides and top first and bottom last. Bottom separates pretty easily with a flat screw driver parallel to bottom face. On the bottom, don't jam it inside where all electronics, wires, and speakers are.
    https://www.youtube.com/watch?v=NtQs...l=Paul%27sTVCo
    Commenter Lord Xibalba in the following video had the exact same problem which makes me think a common problem.
    https://www.youtube.com/watch?v=JXVq...l=TVPartsToday
    This TV repair service indicate they've seen quite a few failures on these low age sets (Mine was 2019)
    https://www.youtube.com/watch?v=mCle...ellTVRepairLLC
  • neilc6
    • Nov 2015
    • 1550
    Re: Fixed dead Samsung UN50NU6900F
    NU series has lots of backlight failures due to edge lit design with lower number of LEDs running brighter and hotter. Rare to see cap failures in LED TVs. Have never seen one personally yet.
    • howardc64
      • Jun 2017
      • 626
      Thanks for the note. I run all LED TVs at 50-60% backlight for longevity. But TV manufacturers love to default to max to for showroom comparison haha.
      • howardc64
        • Jun 2017
        • 626
        Question for people with this TV
        - The chassis randomly clicks. Electrical taped all the fingers and all 4 edges on the rear plate that clips onto steel wires and noise still occurs. Some of the clicks occurs when changing videos (say youtube) The backlight will fade dark and then brighten during the video transition. Maybe related to thermal expansion of the hotter edge lit LED bars? Edge lit LED bars usually have 2sided thermal tape underneath. I've dis/reassembled Apple's monitor with LED bars. Will get clicking if the thermal tape is disturbed and uneven. I wonder if these edge lit Samsung LED bars often have thermal cycling noises.
        - Also get vertical bar section on LED briefly (like 1+ frames) but pretty rarily. Mostly same region on the LCD but once in a different region. Look just like failed LCD edge flex cable issue. Perhaps the integrated main+PSU+tcon board has some noise as 2 caps previously failed. When TV is powered off... very faint sequeal from the board for a littlewhile.
        Anyway, chassis clicks is quite annoying. Seems quite common on this set from online search. Anyone experienced this and have solutions?
        • howardc64
          • Jun 2017
          • 626
          Update for future DIYer
          Random clicking sounds
          Samsung has decided to go screwless on these. Basically snaptite construction everywhere. I taped everywhere the rear case snaps onto the chassis and the 2 metal leg mounts where its metal on metal contact. Clicking seems quite a bit less.
          Another clicking sound occurs often on changing video sources (switching tv channels, streaming video etc) I think the reason is Samsung decided to dim the LED during the video source transition to make it look nicer (can see backlight doing this transition effect with the back panel off). This probably thermal cycles the edge lit LED which seems to sticky tape mounted without any screws. Probably loosens over time. Perhaps the fix is to replace edge lit LED bars with new sticky tapes and likely not worth it until LEDs burns out. Samsung can also remove this dimming video transition feature from the firmware but probably unlikely at this point.
          Vertical noise bars
          Looked like classic LCD edge flex connection issue but only very brief and infrequent. Turns out to be TV's youtube app streaming 4k video (over 2.4GHz wifi) TV broadcast and firesticks work without any problem.
          • alfatv
            • Sep 2020
            • 353
            I am fixing the same model right now.
            Noticed some buzzing noise coming from main board.
            Narrowed it down to one of these 2 inductors, they are in backlight circuit.
            Tone of the sound correlates with amount of backlight.
              09-07-2024, 05:50 AM
            • howardc64
              Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
              by howardc64
              TV was fixed just after removing Samsung's rear snap cover.
              This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
              Maybe PSU->backlight connector didn't have a good contact?...
              07-23-2025, 12:34 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
