I got this tv for close to nothing , i thought i would have a quick work of it and i was so wrong. The issue is the psu is clicking and i get no power , i have 5 volt stby , the light on tv is coming on then off continuously.
I have taken the board off powered it on alone , and still the same issue. I initially bridged the ps-on pin on the 804-2 connector with 700ohm resistor and nothing happened. Then when i bridge with a screwdriver i hear a double click (2 relays) and then quickly the relays go open and stops untill i release
and bridge it again. I have checked every single transistor on the primary side and the secondary side aswell , checked most of the capacitors with esr meter , and i couldnt find any faults.
When the ps-on is not pulled down i have 2.8volts on it. And other then the 5volt, thats all she wrote.
I probed other points to see if the voltages come up briefly when i close the relays but no. I think there is no oscilation happening of any sort on primary side. The Main filter capacitors have basically 0 volts on them , when the relays click on there is about 300volts. And now i am stuck , i really dont know where to go from this point on , im suspecting some IC is the issue since i cant find any faulty components on board. Mainly im looking at L6598 PWM controller since i cannot hear any oscilation happening for that brief period of time, and the other circuitry is detecting it somehow and just turning it off.
IF anyone has any more experience on this boards maybe you can point me in the right direction.I have some schematics here , but i will post pictures of the board tomorrow since its quite late right now. The schematic is not completely identical but its there 98% same as mine .
