Hello all,
I'm looking for some help with an ASUS ProArt Display PA278CV that's no longer working after a lightning strike. The graphics card connected to it also failed, which points to some sort of surge.
The monitor powers up and the on-screen display (OSD) menu works perfectly fine. However, it displays a "No Signal" message regardless of whether I use the HDMI or DisplayPort inputs. Since the menu system is functional, I suspect the issue is with the input circuitry rather than the main power supply or the display panel itself. I've already tested the power section, and it seems okay.
The main board looks fairly simple, and the primary IC is a Realtek RTD2788m. I believe this chip, which acts as the video scaler and controller, might be the source of the problem. Unfortunately, I'm having a lot of trouble finding any technical information, like a datasheet, or a reliable place to purchase a replacement.
Has anyone had experience with a similar issue on this monitor or other ASUS ProArt models? Specifically, I'm looking for:
Any guidance or advice would be greatly appreciated. Thanks in advance!
- A datasheet or service manual for the RTD2788m IC.
- A reputable source to buy a new or used RTD2788m.
