Sceptre X405BV -- Backlight on in standby?
  • DoorOfTime
    • Jan 2017
    • 18
    I have a sceptre x405bv TV with bad LED strips. The screen displays dimly over the good LED's, and on disassembling it looks like over half of them are dead tested by multimeter diode test on test points. Plugging it in with the panel disconnected (this TV has a combined power and main board), the backlights immediately receive power when the set is plugged in. When the power button is pressed, it flashes brightly then dims, but additional LED's turn or flicker. When it's turned off again some back lights stay on.
    Before I order replacement strips I wanted to ask if it is typical for LED's to have power as soon as the unit is plugged in/in standby (with the panel disconnected) or if it's possible the board is defective and constantly supplying backlight power which is why so many LED's burned out?
    I can't see through to the LED's through any part of the chassis on this model to confirm backlight behavior when everything was connected, and I'm a bit cagey about trying to re-connect the panel without fully re-installing it for fear of damaging cables.
    Full model number: X405BV-FMQC8CRAV93CG
    In the attachments you can vaguely see the difference in intensity in standby versus powered on (sorry about rotation... it doesn't want to upload with saved rotation)
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sceptre X405BV -- Backlight on in standby?
    Some tv's turn on backlights with t-con disconnected.
    • Diah
      • Feb 2013
      • 6614
      this is in normal LED behavior.. you have leak at PCB or Opto defect. disconnect the MB from PCB and plug in wall did they come on again??
      • pni
        Backlight panel diffuser melt by backlight leds broken
        by pni
        Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
        10-12-2025, 12:08 AM
      • events.b
        Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested good
        by events.b
        Hello, this TV currently has me stumped. As the title states, when I power on the unit, the backlight comes on for 1 second then shuts off. The TV is still on, and I can see the video if I shine a flashlight on the screen.
        Using the LED backlight tester I was able to confirm all LEDs are illuminating and seem to be working correctly when independently powered by this tester, so that leads me to believe there is something wrong with the power supply board.
        Perhaps the great minds here can help me figure it out, as I don't see any thing obviously wrong with it. The...
        02-08-2021, 11:03 PM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • hollox123
        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
        by hollox123
        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
        1. Laptop keyboard doesn't work
        2. The backlight on the laptop keyboard doesn't work
        3. The x2 side LEDs (red) on the laptop don't work
        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
        But I am strongly aiming that it is somehow a BIOS-related problem,...
        05-11-2025, 08:05 AM
      • signal.quest
        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
        by signal.quest
        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
        03-17-2024, 10:14 AM
