Hyundai plasma/LG inside
  • PowerAmpFreak
    • 982
    • Sweden
    Hello.
    A friend of mine heard a loud bang and the screen went very dark, though he still see a picture. The set is LG stuff inside, Ysus and Zsus.
    Does this indicate a Zsus failure? The usual hybrid sickness?
    Some days before the bang he heard strange noise come and go from the set, though no picture problems.
  • Wizard
    • Mar 2008
    • 2296
    Re: Hyundai plasma/LG inside
    Bang is a exploded big capacitor or a YSUS board went or Y-buffer board. Examine them and check fuses.
    Cheers, Wizard
    • PowerAmpFreak
      • 982
      • Sweden
      I powered up the set. Again, loud bang from Ysus.
      Fuses ok on both Ysus and Zsus, but hybrid on Ysus smells burned.
      A question, is it any problem or risk to power up the smps without Ysus board to check if smps regulates correctly on Va and Vs outputs?
      Or will the logic block the smps from running if powered up without Ysus?
      • PlainBill
        • Feb 2009
        • 7034
        LG's training manual suggests unplugging power cable to V-sus and Z-sus if the power supply won't come up to identify the cause of the failure. Sounds like that is an acceptable practice.
        PlainBill
        • PowerAmpFreak
          • 982
          • Sweden
          Changed Ysus and buffer boards. A real hassle to get the flatwires into the sockets on the buffers...can't imagine how anyone would come up with this weird solution. Anyway, the set works now. The bang that was heard came from the Ysus hybrid, though fuse Ok.
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • Salvatore057
            plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
            by Salvatore057
            I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
            Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
            I am lost, should I change the YSUS board? Is the YSUS board damaging...
            04-29-2018, 01:29 PM
          • Flaku_34
            Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
            by Flaku_34
            Introduction:
            Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
            04-18-2024, 12:47 PM
          • JDC
            LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
            by JDC
            Make and Model: LG 60PB6650-UA
            Issue: Turns on, no backlight, can hear static (no channel)
            I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
            The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
            This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could...
            09-13-2018, 02:12 PM
          • divingfe
            LG Plasma 50PA5500. Sound, no picture !!
            by divingfe
            Sorry if this is too repetitive, or in the wrong place.
            I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
            I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
            06-19-2021, 06:36 PM
