Finlux 50F8075-T flicker
  • sniktaw
    • Nov 2019
    • 9
    • United Kingdom
    Have a regular flicker across the full panel on any source per the video here: https://youtu.be/dx0vBQTk2VE
    Is it likely to be the T-Con, PSU or something else?
    Many thanks in advance, Darren.
  • sniktaw
    • Nov 2019
    • 9
    • United Kingdom
    Re: Finlux 50F8075-T flicker
      • 12323
      • U.S.
      maybe bad connection in the backlights.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would say t-con or panel issue
          • 12323
          • U.S.
          Ah, I didn't look at the video, yes I think you are right Dskall, maybe check the little ceramic caps on the panel driver board, tape cut-off method may work.
            • 12323
            • U.S.
            something to try whenever you have this double image thing is lighten the load, turn off all the video enhancement crap, ambient light if equipped and all that other crap, turn down the backlights, NOT brightness and see if the display changes any.
            • sniktaw
              • Nov 2019
              • 9
              • United Kingdom
              Thanks all, plenty to try. Much appreciated ;o)
              • sniktaw
                • Nov 2019
                • 9
                • United Kingdom
                Great news - fixed! Issue isolated to left side of screen by disconnecting t-con ribbons. Used tape cut-off as suggested by nomoresonys to block clocks and all is good ;o)
                Also noticed a bad cap on the PSU so will replace as preventative measure.
                Thanks guys.
                  • 12323
                  • U.S.
                  Glad to hear it, you don't suppose that bad cap was causing the whole problem?
                  • sniktaw
                    • Nov 2019
                    • 9
                    • United Kingdom
                    Could be I guess, Caps should be here Saturday so I'll try and report back. Either way I'm a happy fella!
                    • sniktaw
                      • Nov 2019
                      • 9
                      • United Kingdom
                      Replacing CAPs had no effect on flicker.
                      Thinking of replacing t-con board as I can get one for £10. Board is an LG part: LC500DUE-SFR1 per photo.
                      Are they model specific? Some listings show for 42" TV, 50" TV, etc with usual caveats that part will only work on that TV.
                      thanks,
                      Darren.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        If blocking lines fixed the problem, then you have a panel problem not a t-con problem.
                        • sniktaw
                          • Nov 2019
                          • 9
                          • United Kingdom
                          Ok, thank you. Every day is a school day ;o)
                          • sniktaw
                            • Nov 2019
                            • 9
                            • United Kingdom
                            Can I do anything about the panel problem?
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              If you now have a good picture, you have fixed the problem.
                              • fixit007
                                Samsung flicker - BN44-00932T board or else?
                                by fixit007
                                I picked up this TV that the prior owner said - just died.
                                Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                05-04-2024, 06:14 PM
                              • howardc64
                                UN65TU7000 strobing / flicker
                                by howardc64
                                Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
                                Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
                                Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
                                03-26-2023, 04:37 PM
                              • piernov
                                Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                                by piernov
                                Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                                I suspect corrupt firmware but I haven't been able to find anything for this TV.
                                TV model: Finlux 65-FUC-8060
                                Mainboard: Vestel 17MB130S 23473048
                                Panel: VES650QNTS-2D-U11
                                At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                                06-01-2024, 12:57 PM
                              • sgcampion
                                Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                                by sgcampion
                                My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                                In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                                10-24-2023, 09:39 AM
                              • TechGeek
                                How To Stop CRT Flicker
                                by TechGeek
                                [PART 1 OF 2]
                                Ever gotten a CRT monitor and noticed an irritating flicker?
                                Here's how to get rid of it (or at least make it far less annoying).
                                Method 1: Increase Refresh Rate
                                1) Get to your display settings. This varies from OS to OS.
                                For Windows (95 to 2000, XP to 7 with Icons Mode, XP to 7 with Classic Start Menu
                                (NOT Classic Start))
                                1) Open the Start Menu
                                (For 95 to 2000 and XP to 7 with Classic Start Menu)
                                Click "All Programs", then "Accessories", then "Control...
                                12-14-2019, 09:05 PM
