samsung un50tu8000 and un70yu7000 displays shorted
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I have two of these units un50tu8000 and un70tu7000 that have displays shorted.The unit cycle on and off with lamps coming on and going off.When i remove the lvds cable to screen i get the intro sound on both and sets remain on with lamps on.Both have identical boards and little over a year old.Anyone have this issue?
    • 12206
    • U.S.
    Re: samsung un50tu8000 and un70yu7000 displays shorted
    maybe test the little components, ceramic caps etc. on the panel driver board there where your ribbon cable connects to.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      So i get a lot around 4-500 ohms or im looking for shorted ones.
        • 12206
        • U.S.
        yep, looks like the ohms are ok, are any shorted?
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          No but i will look further.I assume i'm looking for low ohms like 4-5 ohms or close?
            • 12206
            • U.S.
            yeah, they should probably be over 100 ohms.
            • Diah
              • Feb 2013
              • 6395
              ESD diode same to any other NU serie... it will located at the end of the right side bufferboards ( when you look from the back side )... you can check if you have U ribbon on the right bufferboards ... disconected and see if you have 3/4 SCREEN DISPLAY
              you can also masking the pins on MB side if you can located them which goes to the end of the mentioned bufferboards.
                • 12206
                • U.S.
                lots of times it can be cleared up with the tape cut-off method, one of many examples on youtube there: https://www.youtube.com/watch?v=E6gkuTP7Lt0&t=900s
                  • 12206
                  • U.S.
                  yep, was just about to mention the diode packs, good thread there about them: https://www.badcaps.net/forum/showth...d+diode&page=3
                  • sputnikoff
                    • Feb 2016
                    • 203
                    • canada
                    Diah yes i disconnected the U ribbion on both sets and no 3/4 picture,looks like shorted caps on left side.I did find a couple of caps shorted.There is tape method but why not remove the caps?Also my models have one large ribbon cable vs others show two ribbons from main board.
                      • 12206
                      • U.S.
                      for sure better to replace shorted caps if you find them, the taping isn't for that, you may only have one cap short, can remove one at a time to find out.
                      • Diah
                        • Feb 2013
                        • 6395
                        can you show us the Panel bufferboards of both side ?
                        • Fridaycider
                          • Feb 2022
                          • 16
                          • United Kingdom
                          I have the same problem on my Samsung qled tv. Sorry to hijack the thread but can you please tell me how to test diodes ?
                          • sputnikoff
                            • Feb 2016
                            • 203
                            • canada
                            Here are pics of bufferboards Diah.I remove a cap that was reading 59 ohms but 59 ohms still remains.
                            • Diah
                              • Feb 2013
                              • 6395
                              can you tell if these i marked are ESD diode !!!
                              its strange as you said when remove the U ribbon on each side at time no 3/4 picture...
                                • 12206
                                • U.S.
                                so does the removed cap read or still read short off the board and are any of the others still reading short on the board? are the pads it came off of reading short?
                                • sputnikoff
                                  • Feb 2016
                                  • 203
                                  • canada
                                  cap is reading ok pads reading short.I will post pic with microscope tomorrow.Thanks guys for all great help this is awesome forum for sure.
                                  • jason123
                                    • Oct 2015
                                    • 1069
                                    Any update on this? I am having the same problem. Few people are selling LCD Tab BIOS chip. Is this a known failure on these boards? has anyone tried replacing the main board?
                                    Thank you
                                      • 12206
                                      • U.S.
                                      looks like he gave up on it??
                                      • jason123
                                        • Oct 2015
                                        • 1069
                                        Just got a replacement main board and the system acts exactly the same.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
