LG 42LE2R with the '2 seconds to black'
  • lagosta
    • Feb 2022
    • 5
    • Portugal
    I have an LCD TV LG 42LE2R with the '2 seconds to black' issue.
    When I first opened it I noticed some pregnant 2200uF capacitors on the Power supply board and I immediately replaced them:
    But everything remained the same, so I started debugging.
    On the Power supply board we have 2 connectors, one for each Inverter board (Master and slave), checking the voltage everything looks fine
    24 Volts on all 24V pins, 2.7V on 'Bri' and 4.76V on 'Inv' when TV turned ON.
    Next step was to check the Inverter Boards.
    I found the thread for debugging this issue:
    https://www.badcaps.net/forum/showthread.php?t=10419
    I did the flashlight test and I can see the image on the screen.
    Then I tried disconnecting the left CCFL (close to slave inverter) and TV does the same 2 second to black but only the right side of the screen is lit.
    Now when I connected back the left CCFL, the left side doesn't turn on at all. I don't know what is going on with this TV. I already checked and all cables on the Slave inverter board are connected properly.
    Can I get some guidance from you guys?
    • 12322
    • U.S.
    Re: LG 42LE2R with the '2 seconds to black'
    maybe if you have not, check the transistors on those balancer boards, Q15, Q18 etc, and check the little ceramic caps for shorts or low ohms.
    • lagosta
      • Feb 2022
      • 5
      • Portugal
      The Mosfets on the inverter boards are FDD8447L and they all read arround 3.5MOhm from S to D and G to D. From S to G they read 10kOhm.
      I actually already replaced the ones on Master inverter board with new ones and keep getting same values Q15, Q14, Q18 and Q19.
      Regarding the capacitors, you mean C15 and C19? When I start measuring them they are in the order of 200kOhm and start increasing until Mega Ohms.
      In circut they measure 19uF (parallel).
      Regarding the C16,C18,C1 and C62 they also look fine in the 950uF.
        • 12322
        • U.S.
        wonder if you still have a bad cap or 2 on the powerboard, are you getting the boosted around 390 volts on the big filter caps with tv powered on? measured with probe on each leg. be careful HIGH voltage on primary/hot side of board. Yours may be different, ours is 120 volts coming from the wall.
        • lagosta
          • Feb 2022
          • 5
          • Portugal
          You mean the main power board or the inverter boards?
          The main power board has 2 connectors for the inverter boards with proper 24v when TV is ON. I don't think it's damaged.
            • 12322
            • U.S.
            Not sure about this tv, but you can try, unhook cable from powerboard to mainboard, plug power cord into powerboard, see if backlights come on and stay on, it may not work, might have to jumper the powerboard if not.
              • 12322
              • U.S.
              seems like a problem with either the backlights or a backlight connection or one of the inverter/balancer boards.
              • lagosta
                • Feb 2022
                • 5
                • Portugal
                When I unplug the cables from Power board to main board the TV doesn't respond, the status LED is not comming up and even the relay on powerboard is not activated. When I plug it back you hear the relay on powerboard activating and TV goes into standby mode.
                I assume it's either the backlights with a problem or the inverter boards.
                On the inverter boards I already replaced the mosfets Q14,Q15,Q18 and Q19, I checked a lot of SMD capacitors and the 2 electrolytic caps and all looks fine, I just didn't test the transformers.
                How can I test the transformers with a Multimeter? I can't find a schematic so I don't know witch pins connect where.
                If I want to test the lamps, can I go with a 8W CFL? Like explained here:
                https://www.badcaps.net/forum/showthread.php?t=19987
                • ChIck3n
                  Dell u2311h 20000 seconds to black issue
                  by ChIck3n
                  So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                  09-09-2024, 11:44 AM
                • lostone
                  Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                  by lostone
                  Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                  First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                  When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                  05-19-2024, 11:40 AM
                  HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                  This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                  09-12-2024, 02:00 PM
                  MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                  This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                  09-12-2024, 01:58 PM
                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-07-2024, 05:00 AM
