Bell PVR cap replacement
  • bluegirl
    • Feb 2022
    I have recently replaced 6 bad caps on our Bell 9241 PVR. In the one location I had significant difficulty removing the old cap so much so that I think that the location is damaged. I'm wondering if it is possible to somehow fix this location. Please see attached photos.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Bell PVR cap replacement
    Pictures not that good. You can repair traces with some wire, or solder cap. leads to good trace.
    • captainKKK
      • Sep 2018
      • 287
      ehew.....capC119 trace looks breached. can you remove that cap again, alcohol scrube the area and give us a top and bottom GOOD pic?
      • Unspun01
        • Jun 2011
        • 339
        Cap replacement on these Bell PVR units must be done carefully with not too much heat. 350C should be ok. The PCB is not robust, and pulling up or yanking on the capacitors, or wiggling side-to-side to remove the capacitors like many people do will certainly lead to damaged traces in these units.
        If you have bad caps, note the voltage, and capacitance, and polarity, and try to snip the leads to remove the cap before attempting to de-solder or remove the leads.
        Add lots of flux, and fresh leaded solder to make it easier.
        Even with experience it is easy to damage traces on these PVR boards doing a cap replacement.
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • maxlove70
          Need Bios Packard Bell iSTART 2356
          by maxlove70
          Hello, I'm searching Bios for Packard Bell iSTART 2356.
          Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
          Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
          Chipset: AMD 1100
          Part number: 6A69NA01
          BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
          BIOS Release date: 2007-03-05
          BIOS Revision: 0206
          Packard Bell Support for this PC is discontinued.
          Please Help Me !!!!
          Thanks.
          02-16-2023, 11:52 AM
