fujitsu pds4222w-s Plasmavision TV
  • acidophilus
    • Apr 2010
    • 50
    Hey, I have recently aquired a Fujitsu pds4222w-s plasmavision plasma TV that doesnt work. It turns on, and the screen flashes white, and then it shuts off.
    I was wondering if anyone has ever worked on these or has any idea how to trouble shoot it. Thanks.
  • acidophilus
    • Apr 2010
    • 50
    Re: fujitsu pds4222w-s Plasmavision TV
    Oh yeah, and none of the caps look blown.
    • acidophilus
      • Apr 2010
      • 50
      another tidbit of information; The screen flashes, and the unit powers up, for a few seconds, and the green LED is on, and then it turns off and it starts blinking red. I have never worked on a plasma before, but the power seems to go through a few different boards.
      • PlainBill
        • Feb 2009
        • 7034
        I've checked for a service manual and haven't found any available from any place I trust. It sounds like the small signal board has detected a fault. Does the red led blink in any sort of a pattern?
        Post some pictures. Also, look for labels on the plasma panel that give a clue who made it.
        Most of the plasma power supplies I have seen have the power supply outputs labeled. If this one does, check to see if all the supplies are coming up.
        PlainBill
        • acidophilus
          • Apr 2010
          • 50
          • acidophilus
            • Apr 2010
            • 50
            Forgive my lack of experience, but how should I go about checking this?
            • acidophilus
              • Apr 2010
              • 50
              No, it blinks continuously until I take the power off.
              • acidophilus
                • Apr 2010
                • 50
                I found this service bulletin
                http://myweb.csuchico.edu/~wreeder/Fujitsu Service Bulletin PDP-0068-01.pdf
                but there is no IC socket on the main power board, but there is one on the input board.
                • PlainBill
                  • Feb 2009
                  • 7034
                  I see two ways. The best is to give it to someone with electronics experience.
                  A poorer approach would be to use a DMM. This might result in electrocution.
                  PlainBill
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    is it just me or do the big-ass filter caps (2nd pic, pretty much in the middle, 4th pic the ones on the right) look like they are swollen below the top plastic cap..?
                    as for the power supply connectors..
                    4th pic.. the connectors in the top right.
                    looks like they're labeled (just like plainbill said)
                    • acidophilus
                      • Apr 2010
                      • 50
                      I think that might be an artifact of the picture, there is no real obvious swell in person.
                      Ok, they are labeled. Most of them are ground (GND, I am assuming). as well as VS, VA and VE.
                      • acidophilus
                        • Apr 2010
                        • 50
                        I found these on the IC board. the one with the purple on the top seems to be a little swollen.
                        • acidophilus
                          • Apr 2010
                          • 50
                          PlainBill
                          I have tested electronics before, and completed a physics course on circuits and what not. I only have an analog multimeter, but it should work. I'm willing to try.
                          Though my knowledge is limited, I'm trying to learn.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            I suspect this is a lost cause unless someone else is willing to assist you. A few months back I attempted to assist someone else with a plasma TV. Somehow he never seemed to be able to supply the information I requested.
                            If you REALLY want my help, go reread post 4 in this thread, including the link in my signature.
                            PlainBill
                            • acidophilus
                              • Apr 2010
                              • 50
                              Ok, I uploaded the pictures again.
                              • acidophilus
                                • Apr 2010
                                • 50
                                The boards are made by Fujitsu Hitachi.
                                • weirdlookinguy
                                  • Sep 2007
                                  • 1638
                                  PlainBill
                                  This guy can form coherent sentences and provide clear, adequate pictures. Give him a chance.
                                  acidophilus, you won't be able to test much in the way of caps using a standard DMM. You need an ESR meter for that one. Some DMMs can measure capacitance, but ESR is a much better tell of whether a cap is good or not.
                                  • acidophilus
                                    • Apr 2010
                                    • 50
                                    Ok, The outputs are labeled as such:
                                    VCC1
                                    GND VCC1
                                    VE
                                    GND VE
                                    GND VS
                                    GND VS
                                    VA
                                    GND VA
                                    VS
                                    VS
                                    Using a multimeter I was planning on testing each one of these for voltage. How much voltage should I be expecting coming through these? (I was going to test 250V AC)
                                    • acidophilus
                                      • Apr 2010
                                      • 50
                                      I am aware of this, though I was hoping to be able to narrow down the problem to a specific board. I was under the impression that by testing voltage output from the board it would let me know where the problem was, or at least lead me in the right direction. I am doing this for fun and to learn.
                                      Thanks for any help.
                                      • tmwalsh
                                        • Jan 2009
                                        • 119
                                        Milkman, the boards generally produce DC voltages. There is one output that will likely be an AC output, the one that drives the plasma display itself.
                                        I would set my meter to DC, highest setting, turn on the unit, and measure from specified ground, i.e. GND VE, to the pin labeled VE, and so on. Most sets will produce voltages in the ranges of 5,12, and some in the less than 50VDC range. Most sets will have a 'standby' voltage produced to operate the remote control receiver circuit, and used to 'turn on' the rest of the set.
                                        That means that there should likely be a 5v standby voltage, and then 'run' voltages in the 5, 12, and so on. When you press the on button, or use the remote, there would be a change in one of the voltages 'in' to the power supply, from 0 -> 5 or 5->0 signaling the set to turn on.
                                        Using an analog VM works, as long as the ohms internally are high. I don't remember the numbers, but you can 'drag down' a circuit if the meter draws too much current while it is measuring. I have in mind "10,000 ohms/volt" or words to that effect.
                                        The ESR meters mentioned allow for measurement of the equivalent resistance that a capacitor emulates(?) while in use. When caps get old/dried out, the resistance goes up and messes with the circuit, leading to failure. You have to remove the caps from the board/circuit to test the ESR, or at least lift one leg of the cap[hard to do].
                                        tom
                                          Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U9311 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U9311 boardview and LIFEBOOK U9311 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7411 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7411 boardview and LIFEBOOK U7411 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK LIFEBOOK U7511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LIFEBOOK U7511 boardview and LIFEBOOK U7511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:10 AM
