Vizio TV M706-G3 - no Power
  • jbabbs
    • Jan 2022
    • 9
    Hello All-
    This is my first post. I have seen similar posts but none for the mode I'm having issues with.
    Here are the details. When I initially plug in the TV, the white lower corner light will come on for about 10-15 seconds but then fades out. Also, I cannot turn the TV on; either with the manual button on the back of the housing nor with the remote.
    I've tried all the online options I could find but nothing works. Based on a little research i believe its the Power Supply board (or maybe the main processing board). My board doesn't have the easily labeled stby 5 volts marking that I've seen on other vizio power supply boards....so I need some clarification as to which pin on my model is the equivalent to the standby power pin and i also don't know what the correct voltage reading i should be seeing with my multimeter.
    Here are the power supply board markings and the multimeter voltage readings with the unit plugged in:
    (ALSO, see the attached pictures)
    1. VSNS - 2.4
    2. LED-OUT - 64.2
    3. LED-OUT - 64.2
    4. LED-OUT - 64.2
    5. LED-OUT - 64.2
    6. GND - 0.0
    7. GND - 0.0
    8. GND - 0.0
    9. GND - 0.0
    10. GND - 0.0
    11. +16 -16.2
    12. AC-DET - 16.2
    13. PS-ON - 3.2
    14. +16VS - 16.2
    15. +16VS - 16.2
    I'm guessing the stby power pin is #13 "PS-ON," but I suppose it could be 1, 12, or 13. I don't know for sure what the abbreviations for 1, 12, and 13 stand for/mean.
    I also can't find (on this model) what voltages I SHOULD be reading. A lot of similar threads say 5 volts is correct but i saw another that said as title as 3 volts could be correct.
    Confusing!
    Lastly I also read a post/thread that a lower than normal voltage, even though its reading something at the power supply board, might be enough to produce a reading on the multimeter that appress stable and adequate, but in reality the voltage is too low to actually power on the TV
    Pictures attached.
    Thanks again for everyones help!!
  • Storyteller12
    • Jun 2020
    • 625
    Re: Vizio TV M706-G3 - no Power
    Please provide pictures of all the boards. Not just the power supply.
    A lot of Vizios suffer from a symptom like this usually caused by the main board.
    Not sure if that the case for this tv since there is no pic if of it.
    • jbabbs
      • Jan 2022
      • 9
      Here are the other pictures.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Put your meter on ps_on pin and press power button. Voltage should drop. If not mainboard is likely problem.
        • jbabbs
          • Jan 2022
          • 9
          Tried it.....it was a little challenging because i had to have the casing wires connected to the main board to do it.
          I didn't see any power drop when pushing or holding the power button.
            • 12323
            • U.S.
            Wonder if it's an always on power supply, maybe unplug cable from powerboard to mainboard on powerboard side, see if there's voltage at the power on pin, for safety against shorting something out, always make connections and disconnections with tv unplugged.
            • dskall
              • Oct 2016
              • 2905
              • usa
              It does seem odd that you have all voltages up and running under standby. I agree see what PS_ON looks like with main disconnected.
              • R_J
                • 9633
                +16v is the standby voltage, PS_ON turns on the pfc circuit and the led_out supply.
                The led_out voltage (64.2) is likely just residual voltage as the caps are only rated for 50vdc and will drop when the backlight supply draws current.
                I suspect the problem is on the main board
                • Storyteller12
                  • Jun 2020
                  • 625
                  Try heating the BGA chip with a hot air gun or blow dryer and see if it turns on.
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Odd there is not heat sink on that main board.
                    • jbabbs
                      • Jan 2022
                      • 9
                      Storyteller......seriously?? hot air gun or blowdryer?
                      what would heating that chip accomplish?
                      and....which is the BGA chip?
                      • jbabbs
                        • Jan 2022
                        • 9
                        Apologies all....I found an error in my original post: pin #12 AC-DET = 1.4 (not the 16.2 originally listed, sorry for the fat finger error)
                        OK, so, as suggested, I disconnected the main board from the power board at the power board side. Plugged it in and all reading were 0 except:
                        11. +16 -16.2
                        12. AC-DET - 4.3
                        13. PS-ON - 0
                        14. +16VS - 16.2
                        15. +16VS - 16.2
                        When I plugged it all back together again the readings mirrored the original posted readings except:
                        12. AC-DET - 1.7
                          • 12323
                          • U.S.
                          That acdet looks strange but not sure.
                          • Storyteller12
                            • Jun 2020
                            • 625
                            Seriously, this is a big problem with some Vizio TVs. The BGA is the big mediatek chip in the middle.
                            May not be your problem, this main board doesn't have the same design as all the ones that fail. However as I mentioned, I don't see any heat sinks which is odd because a lot of vizio boards fail from heat.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              11. +16 -16.2
                              12. AC-DET - 4.3
                              13. PS-ON - 0
                              14. +16VS - 16.2
                              15. +16VS - 16.2
                              12. AC-DET - 1.7
                              Your original test shows 3.2v on ps-on.
                              • jbabbs
                                • Jan 2022
                                • 9
                                Yes. That new reading is from the suggested procedure. I disconnected the main board from the power board.
                                that was the PS-ON reading at the pin on the power board
                                • jbabbs
                                  • Jan 2022
                                  • 9
                                  Maybe i'll just replace both boards and cross my fingers.....shopjimmy has all three boards in a combo pack for a reasonable price.
                                    • 12323
                                    • U.S.
                                    That surely could be the quickest solution, as long as the panel and backlights are ok.
                                    • jbabbs
                                      • Jan 2022
                                      • 9
                                      FIXED!!!
                                      Just bought the combo pack of all three boards.
                                      Replaced the power board and main board.
                                      rechecked the new power board voltages and they were the same as the old board....apparently it was the main board as someone earlier mentioned.
                                      Thanks everyone for your timely responses and help!
                                      Fixed for under $150
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                        09-06-2024, 05:59 AM
                                        HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-12-2024, 02:15 PM
