Vizio E480i-B2
  • imraneesa
    • Dec 2016
    • 6
    • trinidad & tobago
    Vizio E480i-B2
    Hi all
    I am trying to troubleshoot the above mentioned tv power supply board. The pwm ic Ld7913 was bad and I changed it. Also R915 was open and one zener diode was short.
    There is one diode in the secondary section for standby 5v was short also.
    After replacing all bad parts now I am only getting 1.75v on vcc pin of pwm ic. Any help will be highly appreciated. Thank you. There is also another ic that detects AC i guess IN1s101.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E480i-B2
    LD7913 shows as a mosfet. What pwm are you talking about?
    • imraneesa
      • Dec 2016
      • 6
      • trinidad & tobago
      Re: Vizio E480i-B2
      Ld7913JGM6 is 5 pin Ic
      • imraneesa
        • Dec 2016
        • 6
        • trinidad & tobago
        Re: Vizio E480i-B2
        Here is the picture of ic
        • lotas
          • Jan 2016
          • 4753
          • Russia
          Re: Vizio E480i-B2
          Try also replacing the optocoupler (817) and adjustable zener diode (431).
          • imraneesa
            • Dec 2016
            • 6
            • trinidad & tobago
            Re: Vizio E480i-B2
            I changed optocoupler. I forgot to mention. But even though these two parts are bad shouldn't there be good vcc on pwm ic?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Re: Vizio E480i-B2
              Can't find datasheet. I assume it gets it's initial voltage off main input. Then off of primary winding to supply run voltage. Need to check the diode and capacitor on vcc.
              RJ would be the go-to guy on this.
              • imraneesa
                • Dec 2016
                • 6
                • trinidad & tobago
                Re: Vizio E480i-B2
                I hope RJ get some chance to help in troubleshooting this problem.
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • asr
                  Finding replacement diode iPad Pro 3rd gen A1701
                  by asr
                  Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                  Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                  07-09-2024, 06:24 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • unimatrix93
                  TV backlight zener diode
                  by unimatrix93
                  Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                  So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                  Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                  The led strips has 9 6V leds.
                  02-10-2025, 12:13 PM
