Panasonic TX-L42ET5E
  • Skopsko
    Letkum
    • Sep 2019
    • 7
    • Macedonia
    Hello to all.
    I need bin file for 25P40 ic9350.
    https://****************/dump/lcd_pd.../289-1-0-69830
    I cannot download from remont-aud, so if someone have the privilege to do that, I will appriciate it.
    The TV is blinking couple of times green diode code, after few seconds is blinking red for 10 times, so according to some forums, this file hopefully will resolve the problem.
    Thanks in advance.
  • lotas
    • Jan 2016
    • 4899
    • Russia
    Re: Panasonic TX-L42ET5E
    Originally posted by Skopsko
    Hello to all.
    Thanks in advance.
    You are welcome!
    • Skopsko
      Letkum
      • Sep 2019
      • 7
      • Macedonia
      Thank you so much!
      • riparo
        Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
        by riparo
        Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
        I attach a link to download the service manual, thank you for anyone who can help me
        https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
        01-11-2024, 12:35 PM
      • SLB007
        Panasonic TX-32C300B stanbye light blinking 13 times
        by SLB007
        I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
        11-02-2025, 04:08 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • CoinCoin88
        Panasonic PF50G20S blinking 13 times
        by CoinCoin88
        Hello there,
        Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
        Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
        06-30-2023, 05:43 AM
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
