Oled lg 55ec930v
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4458
    • Italy - Milan
    Re: Oled lg 55ec930v
    blocking randomly? which is the tcon model?
    • comptek
      • Aug 2013
      • 606
      This type Davi borrowed from eBay as the tv is all done up for now thanks for your help
      • comptek
        • Aug 2013
        • 606
        Hope this helps
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4458
          • Italy - Milan
          i have to gather one better picture and an android sw for editing it
          • comptek
            • Aug 2013
            • 606
            Can I help what do you need a photo off please Davi
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4458
              • Italy - Milan
              #26
              i was ensuring you were blocking the right traces..
              • comptek
                • Aug 2013
                • 606
                #27
                Ok thanks awaiting your advice thanks again
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4458
                  • Italy - Milan
                  #28
                  Those stupid Android programmers, there isn't any that programmed a landscape view photo editor..
                  • comptek
                    • Aug 2013
                    • 606
                    #29
                    Oh dear see what you can do I appreciate everything you do thanks
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4458
                      • Italy - Milan
                      #30
                      The traces to block are the group on 1 or on 2 , it is impossible to know without to try.. but this on the faulty side..
                      • William1967
                        • Nov 2017
                        • 215
                        • Netherlands
                        #31
                        By blocking traces with tape the controller "thinks" there is a mistake and the t-con will go in protection. An Oled t-con works much different that a LED t-con.
                        • comptek
                          • Aug 2013
                          • 606
                          #32
                          Thanks I will give it a go Davi thanks again my friend
                          • comptek
                            • Aug 2013
                            • 606
                            #33
                            Oh I see mmmm what to do now lol
                            • comptek
                              • Aug 2013
                              • 606
                              #34
                              (Just a quick update) Well a bit of a change it’s starting to flicker now without any clk lines blocked the top 3 quarters darker shading disappeared for an hour then when I moved it it can back cleaned lvds cables with proper cleaner still flickers every no and then and sometimes I move the screen and it clears to a perfect picture
                              Thanks to Davi and William1967 for the advice and help so far
                              • comptek
                                • Aug 2013
                                • 606
                                #35
                                Here is the screen when the top half has cleared
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4458
                                  • Italy - Milan
                                  #36
                                  Maybe a defect of a connection within the panel like it happens on lcd tv, but need to know how are made these panels, if there are cof tabs on the side of them, in lcd world we can add a thin wire to rebuild the connection..
                                  • comptek
                                    • Aug 2013
                                    • 606
                                    #37
                                    You could be right there Davi thanks for your help 😁
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      #38
                                      Looks like failed gate driver on left side. You are only getting half the resolution in that section. Maybe disable VGH on that side to even out the resolution.
                                      • Diah
                                        • Feb 2013
                                        • 6435
                                        any one talking on blocking feed line on OLED panel mean he never had oled one under his hand.. so don't play with it any more..
                                        there are resistances record saved automatically at the T-CON eeprom firmware, registered the working hour and view setting condition beside the charge and discharge of the Micro Leds. it mean if one line (pixel Line ) get out of order doesn't mean always its total Panel fault.
                                        IN_STOP command or downgrade then upgrade firmware will help too. be caution OLED Panel should never never never disconnected from T-CON at any case. then you will have more line and distribution at picture.
                                        • comptek
                                          • Aug 2013
                                          • 606
                                          #40
                                          Hi guys moved it on now it was very intermittent
                                          Just waiting for a tcon for the second one now same model but has banding on the screen which I gather is common
                                          Thanks again guys
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
                                            Gigabyte AERO 14 OLED BMF-72USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72USBB4SH boardview and 14 OLED BMF-72USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:38 AM
