Oled lg 55ec930v
  • comptek
    • Aug 2013
    • 606
    Oled lg 55ec930v
    Hi Guys, I have the above tv here, first of all when I got it all it did was click etc, cracked all boards over for dry joints burns etc nothing found.
    Used IRBlaster to power on, then used tv remote to turn off and reinstalled everything all ok except there's a line on the screen shown in photo it seems to fade out on the right hand side
    The line is just before the end of her nose
    Any ideas please
    Thanks in advance
    Gary
  • TeslaMichael
    • Oct 2020
    • 102
    Re: Oled lg 55ec930v
    Did it shut off again after using, or still working ? I got maybe a idea
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4459
      • Italy - Milan
      The fault is in the panel itself, pretty obvious, like led tv ones.. it would be curious if you find the same similar circuits on the screen borders than lcd ones.. but not sure if you can fix it..
      • comptek
        • Aug 2013
        • 606
        Hi Tesla No it runs perfect was on for 6 hours yesterday
        Be great to hear your idea thanks
        • comptek
          • Aug 2013
          • 606
          Davi.p Thanks for the input, I think it’s the panel too but as I have never worked on an oled before I thought I’d ask,
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4459
            • Italy - Milan
            there is one dead gate driver, difficult on how to isolate it, maybe with tape like lcd..
            • comptek
              • Aug 2013
              • 606
              I wondered if it was possible to do that that's why I asked on here thanks Davi.p I might give it a try but it's hard to tell if it's the top or bottom that's at fault
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4459
                • Italy - Milan
                top or bottom what?
                • TeslaMichael
                  • Oct 2020
                  • 102
                  Oh i didn't expect that this tv will work fine without powering off. Yes it's sure the panel. I'm not thinking that t-con can be the issue.
                  • comptek
                    • Aug 2013
                    • 606
                    top or bottom what?
                    Of the screen as it's different shades if that makes sense
                    • comptek
                      • Aug 2013
                      • 606
                      Ok cool I will await what the owner wants to do
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4459
                        • Italy - Milan
                        The bad colors are the top if tcon is on the bottom, otherwise the opposite, but the faulty part is only the line , after that all lines are affected due to a control signal tension flaw, for example VGH.. the short in single driver generates a tension drop...
                        • comptek
                          • Aug 2013
                          • 606
                          Is it ok disconnecting tcon to screen lvds cables as you would do on lcd screens to narrow Down the damaged line
                          Tcon is at the bottom of the tv
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4459
                            • Italy - Milan
                            Do it at your own risk, from what see in photos you can disconnect one half, but better to keep connected both two of that half because one is most p.supply, the other all signals, i think is no good connect only supply one..
                            • comptek
                              • Aug 2013
                              • 606
                              Thanks I will see what the guy wants me to do
                              • comptek
                                • Aug 2013
                                • 606
                                Well it's now mine to scrap or try and fix it 😁
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4459
                                  • Italy - Milan
                                  Cavolo!
                                  • comptek
                                    • Aug 2013
                                    • 606
                                    Cavolo!
                                    I have been called worse ...... Cabbage lol
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4459
                                      • Italy - Milan
                                      No, cavolo is expression of surprise in Italian.. assonance with ca**o (fu*k)...
                                      • comptek
                                        • Aug 2013
                                        • 606
                                        😳 lol thanks for your help anyway
                                        The tv is still working with the line tried blocking no joy yet
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          Gigabyte AERO 14 OLED BMF-72USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72USBB4SH boardview and 14 OLED BMF-72USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
