Samsung ue49mu6120
This topic is closed.
  • dani.m
    • Nov 2023
    • 12
    • italy
    #341
    Re: Samsung ue49mu6120
    i find it
    • dani.m
      • Nov 2023
      • 12
      • italy
      #342
      asprogrammer tells me "access violation Press ok to ignore and risk data corruption.press Abort to kill the program." when i push detect ic button.
      Now even the original main has stopped working, do you have the file to reprogram it?
      • lotas
        • Jan 2016
        • 4594
        • Russia
        #343
        Cy-gm055hghv3h
        • dani.m
          • Nov 2023
          • 12
          • italy
          #344
          I'm trying with Asprogrammer to detect my chip but the list is empty
          • dani.m
            • Nov 2023
            • 12
            • italy
            #345
            The file I had saved after reading the 25Q80DV of the MU6120 is the same as the one you gave me,
            Now the TV looks like this with both boards
            • dani.m
              • Nov 2023
              • 12
              • italy
              #346
              Trying with the original board (MU6120) and detaching the upper flat I managed to get half the image right, if I detach the lower flat you can see the other half
              • coofe
                • Oct 2019
                • 7
                • slovakia
                #347
                Hi can i ask for help again
                49MU6272UXXH
                BN41-02568B BN94-12486H
                IC1604 W25Q40CL
                standby problem and restarts
                • lotas
                  • Jan 2016
                  • 4594
                  • Russia
                  #348
                  49MU6272UXXH
                  IC1604 W25Q40CL
                  Your dump is working.
                  • coofe
                    • Oct 2019
                    • 7
                    • slovakia
                    #349
                    thx will try program again
                    • Leon85
                      • Nov 2023
                      • Malvito
                      #350
                      Ciao sono nuovo,
                      vorrei chiedere se qualcuno ha lo schematic diagram di questa scheda
                      samsung BN94-12570P,
                      UE49MU6120KXZT
                      • Jeffaas
                        • Jan 2021
                        • 9
                        • Nederland
                        #351
                        hi Lotus could you also fix my dump if you have time? thanks already for youre time!
                        • Jeffaas
                          • Jan 2021
                          • 9
                          • Nederland
                          #352
                          thanks! i hope you can open it ?
                          • lotas
                            lotas commented
                            Editing a comment
                            It (dump) is fine for you, it’s working, so the problem is somewhere else.
                        • Jeffaas
                          • Jan 2021
                          • 9
                          • Nederland
                          #353
                          Oke, thank you very much for the time! You have any idea what the problem could be? Voltages are all present and oke. The standby led flashes once about every 8 seconds
                          • lotas
                            • Jan 2016
                            • 4594
                            • Russia
                            #354
                            If the problem was in this firmware, then the standby indicator would not light up at all, you may have a problem in the panel, first disconnect the cable between the power supply and the motherboard and turn it on, only the backlight should light up, then connect it back and disconnect the LVDS cable from motherboards and panels and reapply power and test the TV’s response.
                            • Jeffaas
                              • Jan 2021
                              • 9
                              • Nederland
                              #355
                              The panel is not the problem.
                              The backlight and the panel are good.
                              maybe the chip itself is bad. I will write my old dump back to a good chip and look what it does.
                              maybe the bga is the problem.
                              • lotas
                                • Jan 2016
                                • 4594
                                • Russia
                                #356
                                Check the hdmi and usb signal lines relative to ground.
                                • marciano
                                  • Nov 2012
                                  • italy
                                  #357
                                  Hi guys
                                  I have a samsung UE43MU6125KXZT with a BN41-02568B that have the power LED off, With the CH341 I have read the memory and in attachment you have the BIN file. Is possible to Fix?
                                  The memory is 25Q40CLSIP, I als have some problem to et the QE to 1......
                                  Thank you!
                                  • lotas
                                    • Jan 2016
                                    • 4594
                                    • Russia
                                    #358
                                    Originally posted by marciano
                                    Hi guys
                                    Thank you!
                                    Try
                                    • marciano
                                      • Nov 2012
                                      • italy
                                      #359
                                      Hi Lotas,
                                      THank you for the help, now the TV is working.
                                      Regarding the problem of the QE setting to 1 I have used a new version of Asprogrammer and it works.
                                      Where did you take the first part of the corrupted BIN file? Is it common for all the Samsung versions?
                                      Just copy and past with an editor?
                                      Best regards.
                                      • lotas
                                        • Jan 2016
                                        • 4594
                                        • Russia
                                        #360
                                        Hi Lotas,
                                        Best regards.
                                        Each software version has its own firmware and they are all different.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
