Samsung ue49mu6120
This topic is closed.
  • gaffer82
    • Jul 2023
    • 5
    • ireland
    #361
    Hi, Lotas!
    I have samsung 55MU6400 with mb bn41- 02568b (bn94-11958Q)
    the Tv does not work, the red Led does not light up, and when the MB is turned off, the baccklight works. Could you please fix the firmware for it?
    • lotas
      • Jan 2016
      • 4595
      • Russia
      #362
      Hi Try.
      • gaffer82
        • Jul 2023
        • 5
        • ireland
        #363
        Thank you very much, but the TV still doesn’t work, there is no response to the power button, I set the status register as it should, but after turning on the beginning of the dump is destroyed, please tell me what could be wrong.Click image for larger version  Name:	image.png Views:	0 Size:	13.2 KB ID:	3172713
        • lotas
          • Jan 2016
          • 4595
          • Russia
          #364
          What programmer do you have? If CH341A, what program do you use for it?
          And how do you record the dump, what is the order in which the commands are executed?
          • gaffer82
            • Jul 2023
            • 5
            • ireland
            #365
            I read the dump with SVOD3 , but the status registers in it are not entirely clear, so I took another programmer - Chipprog-48. I pasted a picture with the status registers from it
            • gaffer82
              • Jul 2023
              • 5
              • ireland
              #366
              when I read the dump again, I see that the beginning is FF, I load fix , I click erase then write, then in the security register column I select read, I go into them, I see that everything is still the same as I set it up​
              Click image for larger version  Name:	image.png Views:	0 Size:	254.7 KB ID:	3172739
              • lotas
                • Jan 2016
                • 4595
                • Russia
                #367
                The procedure is as follows: 1 - Remove protection (uncheck all checkboxes and record St. Reg.) 2 - Erase the chip. 3 - Record my Dump. 4 - Check the recorded dump. 5 - Check the boxes in the Status Register (0x88, 0x42, 0x00) and write to these registers.​
                • lotas
                  • Jan 2016
                  • 4595
                  • Russia
                  #368
                  Why do you have errors on 2 pins?
                  • gaffer82
                    • Jul 2023
                    • 5
                    • ireland
                    #369
                    Thank you very much, after 10 attempts with the SVOD programmer I was able to write the registers correctly, the TV started up! Thank you!
                      Vesko356 commented
                      Editing a comment
                      This is an english language forum, post in English ONLY please!
                  • lotas
                    • Jan 2016
                    • 4595
                    • Russia
                    #370
                    Ok!
                    • Martin_CZ
                      • Jan 2021
                      • 9
                      • Czech
                      #371
                      Dear guys,
                      can I ask You for modification of this dump? Many thanks. Martin
                      • lotas
                        • Jan 2016
                        • 4595
                        • Russia
                        #372
                        Originally posted by Martin_CZ
                        Dear guys,
                        Try.
                        • Martin_CZ
                          Martin_CZ commented
                          Editing a comment
                          Thank You. It works!
                          One more question - how to modify dump? I checked some dumps form You from this side, I see differences from 0 to 01000 address but this countain is different from different dumps.
                          Martin
                      • Martin_CZ
                        • Jan 2021
                        • 9
                        • Czech
                        #373
                        Please I have just one dump for modification. Thank You
                        • lotas
                          • Jan 2016
                          • 4595
                          • Russia
                          #374
                          They differ because they have different software versions.
                          Try this one.​
                          • Martin_CZ
                            Martin_CZ commented
                            Editing a comment
                            working. thank You. There is a chance to do tutorial how to modify dump?
                        • gunjanksh
                          • Jul 2016
                          • 8
                          • Nepal
                          #375
                          Repair this please it restarts and shows distorted graphic screen.
                          • lotas
                            • Jan 2016
                            • 4595
                            • Russia
                            #376
                            Your dump is working, the problem is different.
                            • sakistech
                              • Nov 2014
                              • greece
                              #377
                              hello ...can you check if this is files is correct UE55MU6122KXXH Thank you
                              • lotas
                                • Jan 2016
                                • 4595
                                • Russia
                                #378
                                25Q40 is working, on the second one you need to write what the panel is and what’s wrong with the TV, why they decided that the problem was in the firmware.
                                • Dan_TV
                                  • 7
                                  • italy
                                  #379
                                  Hi Lotas,
                                  I have a UE49MU6120KXZT with BN41-02568A and BN94-12570P with BIOS issue,
                                  can you help me please. THX
                                  • lotas
                                    • Jan 2016
                                    • 4595
                                    • Russia
                                    #380
                                    Originally posted by Dan_TV
                                    Hi Lotas,
                                    Try.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
