LG OLED 55EG9100 TCON troubles
    Re: LG OLED 55EG9100 TCON troubles
    Originally posted by Diah View Post
    you are just jumping between solutiones, mean while i never heared on this heating error..
    rollingback firmware more easy.. because downgrade you need old firmware version which LG remove them from download. unless you write at any forum of this model if some one upload it for you.
    however i will try to write to you later how to rollingback the firmware.. mean while when you install the old T-CON did you screw it complete with the metal shield and chassis ?
    Hi
    I find on a china lg website any firmware version for C9 , I try with the USB to install but dose not see any file the TV .. what options are to downgrade firmware if I have the early files?
    Thank you
      sorry man.. i cant share my mind with subject you are running unclear to us.. you have 2 OLED and you exchange parts between them.. TV OLED like pc when take the hard disk from PC to pc.. when you exchange parts this parts should register the new hardware against the old registered... some time this make JAM
        Sorry for misunderstanding, I have extra motherboard C9 which it's already upgraded on the B8 TV ( it's a different story)
        It's dosed have nothing to do with my other C9 TV which I was talking about and try to find solutions to match the new T-CON to the panel or to find a solution to fix the old and original T-CON from the TV
        Thank you
          Like I said it's a different story and I also said maybe I will talk about the B8 upgrade later ( for you maybe sounds not good idea ) and I have done it 9 month ago , and still working as normal.
            here how to do in German language.. you can translate it to English via the browser. it is very easy.. attached also the Apache server.
              Hi, thank you, I will try now .. I let you know later how it's going on , thank you again
                Nothing change in the ( in_dumb.txt ) the model_NM of the TV
                Everything it's done except in_dumb.txt
                  Everything it’s done except in_dumb.txt
                  in_dumb.txt is just quide to know the name of new file generated under C:\LgDTVUpDater\htdocs for exampel HE_DTV_XXXXX_XXXXX so look after which file generated new ... you will know this when your PC explorer setting can show the exit type of the file and date time stamp. also you can delete the perviouse in_dump.txt content it will generate new one
                    I did probably 5 times and still not come up the model in the in dumb.txt nothing change on the files
                      show me screen on \LgDTVUpDater\htdocs show all files, or use this blank file instate the one you have
                      well i think its not my job to teach computer science over here.... or !!!
                        Thank you for taking from your time, but stii the same nothing written even on blank files
                          yours pc firewall blocking communication , or you write the ip gate way on the tv wrong
                            No luck same , I try wifi, wired connection same , I even try 3 firmwares and the original one too
                              with wifi never work... only LAN
                              GATEWAY --- yours PC IP
                              DNS Server ---- yours PC IP
                              yours PC should with LAN too
                                Hello there,
                                I have the same issue. After some vertical Lines on my LG OLED C7D, i swapped the T-Con Board.
                                With the new Board, the lines are gone, but i see ghost logos like "Dolby Vision" "HDR" etc. all over the Screen.
                                I wanted to downgrade my OLED and update it again, but i cant find an older version of the firmware... Does anybody know where i can find it? My firmware is 6.00.25.
                                  Originally posted by Big_Whity View Post
                                  Hello there,
                                  all LG TV series from 2014 to 2021 ( old & new web OS Firmware ) can downloaded from LG server with help this site server,
