LG OLED 55EG9100 TCON troubles
  • Andrei_UK
    • Dec 2021
    • 30
    • United Kingdom
    Re: LG OLED 55EG9100 TCON troubles
    Originally posted by Diah
    can you show us here same page IN_START of the original T-CON in place ?
    did you sent IN_STOP before while original T-CON in place ?
    Hi , I remember now that I did update to last version firmware when I fix all the parts ( new motherboard, new T-CON from broken screen tv ) to the panel with the T-CON that switch off after few sec with messages in IN-StART “power_off_due_to_cooling”.
    I did IN-STOP after few refresh pixel and nothing changes from the vertical bands
    If I swap the old T-CON even with his original motherboard or new motherboard will work but like I said it's switch OFF after 30 sec
    See pic attached with the good panel and new motherboard + OLD t-con
    • Andrei_UK
      • Dec 2021
      • 30
      • United Kingdom
      I did IN-STOP with the Original T-CON then boot restart and same as usually turn off tv ( POWER_OFF_BY_COOLING(0x65) message on IN-START at Power ON/OFF status
      • Andrei_UK
        • Dec 2021
        • 30
        • United Kingdom
        I believe that any OLED 2019 up the panel ( screen) come with his T-Con board some how are married panel+t-con
        So for my first post, was about if it’s possible to copy data from the Old T-CON without soldering the chip , and then write the data in to the new T-CON ( probability T-con and panel share same information)
        But before that like Diah said to try rollingback or downgrade the firmware and then give a try install old firmware in to the tv and see how it’s going on
        • Diah
          • Feb 2013
          • 6357
          it tell the story from yours last IN_START photo.. the old T-CON matching with Panel. the new one was NG also the interface of the new T-CON are different from the old one. wait of yours USB JTAG and do the eeprom work or downgrade
          • Andrei_UK
            • Dec 2021
            • 30
            • United Kingdom
            Hopefully today will arrive the USB JTAG , and I will write any updates here.. fingers crossed
            Thank you again for taking from your time to write and share your suggestions and knowledge
            • Andrei_UK
              • Dec 2021
              • 30
              • United Kingdom
              #26
              By the way the eeprom chip it the one i made a sign?
              • Diah
                • Feb 2013
                • 6357
                read the lable of it and you will know for sure
                • Andrei_UK
                  • Dec 2021
                  • 30
                  • United Kingdom
                  #28
                  Thanks, I will do that, can wait finish the job .
                  • lotas
                    • Jan 2016
                    • 4554
                    • Russia
                    #29
                    The photo does not show the EEPROM, what you labeled as mosfet transistors.
                    The only chip where the firmware is located in this photo is U3 (NAND or EMMC), the marking is not visible in the photo.
                    • Andrei_UK
                      • Dec 2021
                      • 30
                      • United Kingdom
                      #30
                      Hi , thank you, for confirming that, that makes hardly now to read data from the NAND I didn't see in the pic for NAND reading device in the one I just order for eeprom chip
                      Any easy ideea how to copy data from the one you said? Thank you
                      • lotas
                        • Jan 2016
                        • 4554
                        • Russia
                        #31
                        Maybe something is on the back of the T-con.
                        • Andrei_UK
                          • Dec 2021
                          • 30
                          • United Kingdom
                          #32
                          I will check, after job
                          • Andrei_UK
                            • Dec 2021
                            • 30
                            • United Kingdom
                            #33
                            No luck to be flush the NAND the chip looks to sensible to be unsoldered and re soldering
                            I m still searching what parts from the old T-con made to turn off after few sec probably by any parts getting to hot and then go to protection mode , what about the MOSFET ? Can be the problem?
                            • Diah
                              • Feb 2013
                              • 6357
                              you are just jumping between solutiones, mean while i never heared on this heating error..
                              rollingback firmware more easy.. because downgrade you need old firmware version which LG remove them from download. unless you write at any forum of this model if some one upload it for you.
                              however i will try to write to you later how to rollingback the firmware.. mean while when you install the old T-CON did you screw it complete with the metal shield and chassis ?
                              • Andrei_UK
                                • Dec 2021
                                • 30
                                • United Kingdom
                                #35
                                Yes you right should try rollinback firmware, I will really appreciate any suggestions how to do it, whenever you got time.
                                The old T-CON been always with the shield ON to the panel chassis, and I try even without and just the screw , just to see any difference, nothing change still turn OFF , and if you insist to turn on back it's turn off quickly then the first ON … it's coz something getting hot and go in the protective mode I believe
                                • Andrei_UK
                                  • Dec 2021
                                  • 30
                                  • United Kingdom
                                  #36
                                  I have video with the tv ON with the old T-CON the picture it’s quality
                                  https://m.youtube.com/shorts/ctEt7Tq52mA?feature=share
                                  https://youtube.com/shorts/Vo0XRg074VU?feature=share
                                  • Diah
                                    • Feb 2013
                                    • 6357
                                    why you play with LG service RC ??? you dont have its RC????
                                    and why you dont programm the Tv channel ??? or at least feed it with external HDMI signal ???? or play movie mpeg with USB drive ?????
                                    • Andrei_UK
                                      • Dec 2021
                                      • 30
                                      • United Kingdom
                                      #38
                                      Oh, sorry I recorded just to see all the menu settings from the service menu coz like you know the tv turn OFF between 30 sec - 1 min and then to compare with the new T-CON
                                      I do have 3 RC + service RC
                                      I will add new video with Burn Test 5% grey with the old T-CON and a video with my OLED55B8 and the C9 with the old T-con
                                      https://youtu.be/4Um_XMKYzj0 burn test
                                      https://youtube.com/shorts/8wU7d7teWk8?feature=share B8 vs C9 old T-CON damage
                                      • Andrei_UK
                                        • Dec 2021
                                        • 30
                                        • United Kingdom
                                        #39
                                        Maybe later I will talk about the upgrade experiment I have done ( maybe someone will be interested to know or to do it )
                                        I have upgrade my B8 with C9 motherboard I confirmed that all works good on the B8
                                        C9 motherboard + wifi card with the switcher ON/OFF
                                        • Andrei_UK
                                          • Dec 2021
                                          • 30
                                          • United Kingdom
                                          #40
                                          See pic the update works too
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:40 AM
                                            Gigabyte AERO 16 OLED BSF-A3US964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3US964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3US964SP boardview and 16 OLED BSF-A3US964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:38 AM
