More warning about FSP (forton) SMPS
  • Wizard
    • Mar 2008
    • 2296
    Generic TVs of any kind not just one is really favoring these horrible power supplies.
    Every time I get one there is 80% chance of any damage when bad caps occurs especially with "FSP" on it.
    Latest victim: Soyo 32" LCD had typical bad caps in power supply and for some reason this design of SMPS board is slightly different that it used "floating" ground to get 2 different voltages. 12V and one other voltage. Well, voltage rise so much that destroyed a MLCC ceramic capacitor (short), lucky to see the visible crack in the MLCC cap on the mainboard. Fixed now.
    Cheers, Wizard
  • l0lhaxz1
    QN65QN90A - Mainboard MLCC failed - now bootloop
    by l0lhaxz1
    Hi
    I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
    Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
    Came to learn after a bit more research...
    02-06-2023, 08:59 AM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • jescolta
    psu mlcc
    by jescolta
    i came across dead seasonic prime psu with shorted mlcc caps on the modular board, this is the third time i encounter this problem, i usually just removed the shorted mlcc and not replace them since theres a lot of caps around the psu i used to think those mlcc probably does not matter much, i have no equipment to test or proper knowledge for this. i just reuse those psu on low end machines. but few days ago one of the machines have its 2 sticks of ram died, it keep on getting blue screens. 2 sticks of ram died at the same time, its probably something else and not just the ram. in the past when...
    01-01-2023, 10:24 PM
  • abhishekkumar1902
    Huntkey HK340-72FP SMPS shut on load above 2 amps
    by abhishekkumar1902
    I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
    I have checked the following:
    1. All output caps are OK, and all output rails read correct voltages at no load
    2. All output diodes are OK
    3. NTC is ok
    4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
    5. No short in main switching MOSFET
    6. All other components...
    12-18-2022, 09:52 AM
