Original RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
  • tech9pc
    • Sep 2021
    • 49
    Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008. It is not available nowhere on the internet.
    I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which had lost its HDMI ports signals. I baked the board in oven but have not tried to put back in yet.
    Is there a way I could dump the original mainboard 7.T3458HA1000.0008 image to a usb stick and try flashing it onto the 7.T3458HA1000.0003 mainboard I have in the tv now?
    Original Board BD_CV3458H_A_10
    Firmware: 7.T3458HA1000.0008
    C/N: SU-CU-20180601
    Panel LC650RU1A
    Here is link to shopjimmy original board that I am hoping can flash onto the one I got off ebay that has an older 7.T3458HA1000.0003 firmware image on it
    https://www.shopjimmy.com/rca-main-b...on-2-see-note/
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • advant
    by advant
    02-03-2020, 12:25 AM
