Samsung UE49KS7090 (2016) TV - no power, no red light - which part is faulty?
  • bobsapp
    • Oct 2021
    Samsung TV UE49KS7090 (2016).
    No power, no red light. When I unplug the mainboard from the power board, HALF the backlights flash briefly. I made a short video here https://youtu.be/EVikW32p6kQ
    Voltage measurements:
    With mainboard DISCONNECTED, I see all voltages to be ca. 5-7V
    With mainboard CONNECTED I See voltages of ca, 4-6V
    According to the pinout diagram, I should be seeing 13V.
    Would anybody know which part is faulty? Everywhere I read, it is expected that when you disconnect the mainboard, the backlights stay on permanently. But this is not the case with me. I'm suspecting the backlights (which of course are the hardest to repair IMO).
    Thanks a lot for any support.
  • bobsapp
    • Oct 2021
    Re: Samsung UE49KS7090 (2016) TV - no power, no red light - which part is faulty?
    BUMP :-)
    does anyone know which component needs replaced if,m when I unplug the mainboard from the power supply, it results in briefly flashing LED, like in the video?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4463
      • Italy - Milan
      test PSB with some loads..
      • Michael Long
        No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
        by Michael Long
        I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
        Dead / No Power / No Standby Light results after power company had three
        consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
        After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
        09-13-2022, 06:55 AM
        09-07-2024, 05:50 AM
      • badboyzzz
        Samsung UE50AU8072 all time rebooting, backlight ok. Maybe mainboard faulty?
        by badboyzzz
        The motherboard initially receives voltage for VGH, but it constantly reboots. When I remove the flex cable at the bottom, I hear normal sound, but there is no image on the screen and it is black on both sides. This time there is no voltage on VGH.
        03-25-2025, 10:48 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
