Sony xbr-65x900c main board 7 blinks
  • jb_Bak
    • Sep 2021
    • 6
    I've got a Sony XBR65X900C that is shutting down after about 30 seconds with a 7 error blink code. I do see there is a temp error in the service menu before it shuts down. I have replaced IC1400 which the manual says is the temp sensor with another sensor off a parts board. After that didn't work I removed the HDMI switch IC suspecting it to be bad. Still same issue with it removed. What else is on that I2C line that could be causing this? CPU? Nothing feels hot. Still waiting on my thermal camera to arrive that *might* be of use here.
    Any ideas on further getting this board to work? Got plenty of parts boards so swapping out ICs isn't an issue.
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • tvguy12012012120
    Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
    by tvguy12012012120
    I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
    Any ideas as to what would cause these symptoms?
    Symptoms:
    • From cold power-on, picture is perfect.
    • After ~2–3 minutes, the image slowly degrades:
      • contrast collapses
      • colors wash out / look incorrect (greens especially bad)
      • image looks “milky” / flat
    • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
    • Internal
    01-07-2026, 03:30 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
