Seiki TV - No Backlight
  • daveytee999
    • Sep 2021
    • 5
    Think I'm jinxed - since I joined this forum another TV of mine has gone kaputt!
    It's a Seiki - no backlight. Screen is on and works (can see when shining a torch on it).
    Have had the Tv apart and not sure I understand the voltages I'm getting - when tv in standby getting 35 volts DC on the 2 connectors that go to the back light which doesn't make sense to me. When TV switched on it goes up to between 48 and 58 volts.
    All caps and other components look normal, all diodes seem to check out, not tested the caps 'cos I think I have to take them off the pcb to test (is that right?)
    What I don't understand is why both backlights would fail at the same time (as there's 2 connectors) - I guess they are wired in series which explains the high voltages but for both sets to go at the same time seems strange.
    Can take the whole thing apart and get to the led strips if necessary but wanted confirmation that it's highly likely to be the strips that are at fault first.
    Is there a resistance test I can do on the connectors to test this?
    TIA.
  • neilc6
    • Nov 2015
    • 1550
    Re: Seiki TV - No Backlight
    Backlight issues are almost always the backlights themselves. Very difficult to find new strips for these white label models like RCA.
    https://techhometravel.com/lg-ln-ser...ed-backlights/
      • 21571
      Post the model number please
      https://www.badcaps.net/forum/showthread.php?t=24661
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • Yanleb
        Vizio M70-D3 4K with dark spots backlight issue
        by Yanleb
        I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
        On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
        I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
        03-22-2022, 01:06 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
