Does anybody have a circuit for the PSU board in this Wharfdale unit? Looking at the board there is no connection across the isolation line on the PCB for any supply to get across to run the standby circuit where the button and LED on the front panel are so no power means nothing to turn on the main power. Looking at the board and the switch mode device data of the STRW6252 that is the thing controlling the power it appears a signal needs to be put on one of it pins via the isolation transformer. If that is the case it is most likely faulty but I don't want to buy what looks like an obsolete part without some confirmation or if something else could be dead on the low voltage isolated side. Any suggestions would be appreciated as I am guessing and don't really grasp how the power supply gives any kind of standby voltage across the isolation line.
DVDR24HD160F Dead no standby LED
Re: DVDR24HD160F Dead no standby LED
post clear in-focus pictures of both sides of the power supply so we can see what we are dealing with. Are you getting any voltages in the power supply? It might be that there are some bad capacitors in the power supply.Last edited by R_J; 09-27-2021, 06:45 PM.
Originally posted by R_J View Postpost clear in-focus pictures of both sides of the power supply so we can see what we are dealing with. Are you getting any voltages in the power supply? It might be that there are some bad capacitors in the power supply.
Check the value of R102 ( it is the resistor from pin#3 of the switching ic to ground) It should be a low value around 1Ω. If it is open, the ic is defective.
I see a repair kit available from this company http://www.ohmsupplies.co.uk/epages/...roducts/KIT246Last edited by R_J; 09-28-2021, 07:41 PM.
Originally posted by R_J View PostCheck the value of R102 ( it is the resistor from pin#3 of the switching ic to ground) It should be a low value around 1Ω. If it is open, the ic is defective.
The resistor is ok (0.47Ω), so I suspect the ic could be ok as well. If the ic's internal mosfet shorted, it would cause the resistor to go open, this does not seem to be the case.
I would check all the diodes in the secondary circuit and also check that none of the secondary supplies have a low resistance. If there is a shorted component in the secondary ciruit, the power supply ic will go into shutdown.
If you have a way to check capacitors, check C105, or try replacing it. You can also try and check what the voltage is across C105, this capacitor is in the primary (LIVE) and you must be careful checking voltages here as they do not use the chassis as ground but use hot ground, or the negative side of the large electrolytic in the primary. NOTE the primary side is connected directly to the AC mains.Last edited by R_J; 09-29-2021, 04:59 PM.
Originally posted by R_J View PostI would check all the diodes in the secondary circuit and also check that none of the secondary supplies have a low resistance. If there is a shorted component in the secondary ciruit, the power supply ic will go into shutdown.
Sometimes parts just go bad, If the diode is shorted, just leave it disconnected and with the plug that is connected to the 16v (likely goes to main board?) removed. see if the power supply will work. The supply should operate with 2 of the 3 diodes in place just to test if it works.
It could be that there are also bad capacitors in the power supply, If you don't have cap checker/esr meter or scope etc. to check the power supply, all you can do is start replacing parts. You didn't say what the voltages are so it's hard to say what to check.
Originally posted by R_J View PostYou didn't say what the voltages are so it's hard to say what to check.
Measuring the red wire on each white connector the scart connector board reads 1.5V and on the scope it is a square wave but with the plug out hence no load it is a stable 4.25V. There must be something duff on the scart board.
