LG 55LA6908 bad solder on main board
  • ducttape
    • Jan 2021
    • Slovenia
    Hi guys,
    My parents have a 2013 LG 55LA6908 which is suffering from increasing in frequency intermittent issues, such as random shutdowns (POWER_OFF_BY_CPU_ABNORMAL), UI freezing, dying HDMI ports, etc... My guess is bad solder joints under the main BGA IC.
    I was trying to find a new main board for it but I'm unsure of the compatibility between different parts, models/screen sizes and software versions. If someone could help me out with the compatible part numbers it would be very helpful!
    Product code is 55LA6908-ZB.BEUYLJG with LC550EUG (PF)(F1) LCD panel.
    Main board PCB is EAX64797003(1.2), sticker has bar code with "WJM33233C101048 / 897785815 / 55LA660S-LGD / EBT62297952"
    I'm able to copy the EEPROM from the old to the new board, if that helps...
    Thanks for the help!
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 55LA6908 bad solder on main board
    Your part number is EBT62297952. The blank PCB is part number EAX64797003 and it may be populated differently for different models. Sometimes a different screen size main board from the same series may be compatible but you need to compare all the connectors closely. Have you tried a factory reset? LA and LN series aren't known for BGA failures but for bad backlights.
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
    • advant
      by advant
      02-03-2020, 12:25 AM
