Samsung UE 50 RU7092 restart
  • peterkos2
    • Nov 2020
    • 43
    • Slovensko
    Good day.
    If you can advise me on such a problem.
    TV Samsung UE 50RU7092 not even biennial.
    Main Board BN41-02703A
    Power board BN44-00932Q
    Panel+T-Con BN96-45763A
    When I plug it into the socket, the backlight turns on, dims, lights up and then restarts it. I thought the backlight was faulty, but when I unplug the mainboard, the backlight goes full.
    When I leave it overnight without juice and turn it on in the morning, sometimes the logo pops up and then the menu, after a while the image shakes and disappears a bit and again without the image restarts - during restarts there is a sound, the image does not.
    I tried to disconnect one strip from the screen, and turned on- the sound went but the picture does not but responds to the DO buttons to hear that I'm in the menu, not even half of the screen goes, still the same.
    The mainboard I have a spare from 43RU and the HW is almost the same but when I replaced it, it is still the same
    If you could advise if you have the time.
    well thank you
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Samsung UE 50 RU7092 restart
    Its probably a bad panel or ribbon cable that connects the mainboard to the panel. First look for physical damage on the ribbon cables. Also check for shorts on the panel pcb or any overheating component.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4463
      • Italy - Milan
      In theese Samsung bad lights and shorted panel has similar symptom, if you disconnect ribbons from the panel and have sound + backlight always working then a bad diode or cap on panel's boards.
      • peterkos2
        • Nov 2020
        • 43
        • Slovensko
        Good day. Thank you very much for your answers. We have located 4 pieces of resistors overheating, everything looks OK. I soldered the resistors out, measured OK. I soldered back, the picture jumped up and after a while it starts to shake at the bottom. So I soldered out one 59A resistor and the TV got a nice picture. It worked normally, but this morning I turned on the TV and after a while it fell into restarts. I can't measure 6514A parts. Can you advise me how? Are they diodes? How to measure? Thank you for your interest and time
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4463
          • Italy - Milan
          you did not tell where are the resistors, and if the image shakes vertically, get a photo of resistors and where them are..
          • peterkos2
            • Nov 2020
            • 43
            • Slovensko
            Foto
            I soldered the circles out and the red ones back and the green ones not
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4463
              • Italy - Milan
              ok now more clear, from the many threads here on badcaps on various models, also Sony but with Samsung panel, the main culprits are those or one of those diode packs D001/2/3/4, them are overvoltage protections that are to be removed to see if situation improves, first test them all in diode mode, only if you find a leakage you'll remove it, those are connected in some way to those resistors you've felt hot, if i under stand diode packs have one common anode (central pins) at gnd or connected to resistors, the other ones cathodes ( connected to gate drivers clocks), them are tvs diodes, hard to find in those format, but are to be replaced after all.
              • peterkos2
                • Nov 2020
                • 43
                • Slovensko
                Thanks, I just don't know how to measure the diode test-10pin
                I don't have a better datasheet
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4463
                  • Italy - Milan
                  good! Is better than nothing... If i remember opposite zener are used in fact for overvoltage suppression, if you put multimeter in diode mode, between pins 1,2,4,5,6,7,9,10 and 3,8 must read open both ways..
                  • peterkos2
                    • Nov 2020
                    • 43
                    • Slovensko
                    So the error is there and cannot be corrected
                    Thank you all, at least I'm a little smarter
                    But the question is, it didn't actually start somewhere in the glass
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4463
                      • Italy - Milan
                      The damage came from the electrical supply much probably.. destroyed the chip within the glass
                      • tiki66
                        • Jul 2016
                        • 54
                        • Croatia
                        Looks like liquid damage to me, how did you clean LCD?
                        • peterkos2
                          • Nov 2020
                          • 43
                          • Slovensko
                          I don't know, I solved it for a friend
                            09-07-2024, 05:50 AM
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            08-24-2025, 03:47 AM
                          • bohaboha
                            ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                            by bohaboha
                            Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                            04-19-2025, 01:47 PM
                            09-06-2024, 11:40 PM
