Lg 60pa6500 black spots on tv
  • pansatdishman
    • Jun 2013
    • 110
    Re: Lg 60pa6500 black spots on tv
    Thanks I used my multimeter I get weird readings on q302 , q202, and another one , is there something else I should test ? I know I should change those ones
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      What are those weird readings?
      Anything below 500 ohms is a problem.
      • pansatdishman
        • Jun 2013
        • 110
        There low and fluctuating alot compared to the others around 200 and fluctuates
        Q302 auk b2c25 smk0825
        Q282 auk b2c25 smk0825
        Q281auk b2c25 smk0825
        Where do I find them? And the other types on this are
        Rkp30h2a 4p 026 and auk b3103 sf200400sd2
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          You got some part numbers wrong. For q302, q281 and q282 is SMK0825, an IGBT.
          RJP30H2A is an IGBT, nothing comes up with RKP30.
          SF20D400SD2 is a diode.
          If they are suspect of being shorted, then they have be desoldered from the board and tested off-circuit.
          • pansatdishman
            • Jun 2013
            • 110
            Heres pics of the 3 different components and the writing on them . Where can I get these? Thanks also is there something else i should check?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              You can check SF20D400SD2 as Biruslapio says since they are dual diode pack which your meter can test. Unfortunately the best way to test them is if they test short on the board to desolder them and test again.
              • pansatdishman
                • Jun 2013
                • 110
                Thanks if I desolder it I'm just going to change all of them as theres only a few, with new ones, where can I find these ? Do I just search for smk0825 , RJP30H2A and SF20D400SD2 ?
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  #28
                  you can just desolder the legs and lift them up a bit .
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Originally posted by pansatdishman
                    Here's the z sustain board , does it look like theres anything wrong thanks in advance
                    I see 2012, week 50!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • pansatdishman
                      • Jun 2013
                      • 110
                      Okay so I was able to find a parts tv. Bit I'd like to fix both. So I know what's wrong g with the one I got today the main board had the hdmi component ripped off. I tried swapping a sustain boards and it did the exact same thing. So it's not the z sustain, power supply or?
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        #31
                        Test the buffer boards for short-circuit on the output pins.
                        It takes some seconds for the screen to fully recover from these black spots when the sustain issue is solved.
                        The other tv you bought works fine except for the HDMI?
                        • pansatdishman
                          • Jun 2013
                          • 110
                          Okay so I swapped all the boards the issue for the black hazr was the y sustain board. The tv I bought yesterday all that's wrong with it is the hdmi port was broke off the tv so the tv wont power on. So right now I have a working tv, and a y sustain board and a main board with the hdmi port broke off
                          • pansatdishman
                            • Jun 2013
                            • 110
                            Heres the y sustain board, this looks like the issue causing the black haze?
                            • pansatdishman
                              • Jun 2013
                              • 110
                              Heres the control board with the broke off hdmi board with this board the tv wont power on
                              • Biruslapio
                                • Nov 2013
                                • 552
                                • Brasil
                                #35
                                I woundn't have guessed it just by the photos, certainly looked like a Z-SUS fault.
                                I see no problems in the picture, only that it has a dot that has been resoldered, that brown stuff is flux, either at the factory or someone else touched only that spot.
                                If you want to fix the Y sustain follow the same procedures that I pointed at #16 and measure the main voltages it produces, -VY and VSC.
                                • pansatdishman
                                  • Jun 2013
                                  • 110
                                  For the main board should I just get another hdmi port and which one am I looking for thanks
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    If you see any shorts where the hdmi port came off run your iron over them to remove them. The board will still work fine without the port there provided the cpu isn't seeing a short.
                                    • pansatdishman
                                      • Jun 2013
                                      • 110
                                      Yeah the board isn't working without the hdmi, and I see the board is missing one trace for it
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        The main board should work with the hdmi port removed can you upload a picture of the missing trace area
                                        • pansatdishman
                                          • Jun 2013
                                          • 110
                                          Here
                                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                            09-12-2024, 02:00 PM
                                            MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                            This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 01:58 PM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook Specification for Upgrade or Repair
                                            This specification for the LG Gram LG gram 16Z90P-K.AA85A1 16GB_512GB - Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the LG gram 16Z90P-K.AA85A1 16GB_512GB - Black boardview and LG gram 16Z90P-K.AA85A1 16GB_512GB - Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                            09-07-2024, 03:40 AM
