mytv te32
  • Zac
    • Jan 2020
    • 15
    • Italy
    mytv te32
    hi all, I have a tv that remains fixed in stand-by, sw mp022-jd power supply would seem ok. i think about a firmware problem, the mather board is a cv306h-f. the eeprom memory 25q32fvsic.
    I would need a firmware via usb, or a bios for eeprom. thanks to all greetings zac.
  • lotas
    • Jan 2016
    • 4595
    • Russia
    Re: mytv te32
    Post your non-working firmware dump here, I'll try to fix it.
    • Zac
      • Jan 2020
      • 15
      • Italy
      Re: mytv te32
      thanks for the answer, the discharge from the eeprom? in what format?
      • lotas
        • Jan 2016
        • 4595
        • Russia
        Re: mytv te32
        Originally posted by zac
        thanks for the answer, the discharge from the eeprom? In what format?
        .bin
        • lotas
          • Jan 2016
          • 4595
          • Russia
          Re: mytv te32
          Unsolder 25q32fvsic, read its contents (firmware) on the programmer, save and upload this file in BIN format.
          • Zac
            • Jan 2020
            • 15
            • Italy
            Re: mytv te32
            here I am ... hello LOTAS, sorry for the huge delay.
            • lotas
              • Jan 2016
              • 4595
              • Russia
              Re: mytv te32
              Try it, don't be surprised that the dump size has become smaller.
              • Zac
                • Jan 2020
                • 15
                • Italy
                Re: mytv te32
                hello lotas ...it doesn't open with win.ra ... it tells me damaged archive
                  • 20867
                  Re: mytv te32
                  Update winrar or use 7-zip
                  • lotas
                    • Jan 2016
                    • 4595
                    • Russia
                    Re: mytv te32
                    Update WinRar
                    • Zac
                      • Jan 2020
                      • 15
                      • Italy
                      Re: mytv te32
                      eeprom file working at the first try .. perfect thanks lotas .. the tv had corrupted file, probable forced shutdowns ... question if the same defect occurs again, can I put the .bin file you restored on usb and boot directly from the tv?
                      • Zac
                        • Jan 2020
                        • 15
                        • Italy
                        Re: mytv te32
                        • raileanu
                          • Sep 2015
                          • 126
                          • United Kingdom
                          Re: mytv te32
                          Thank you lotas it works perfectly.
                          • NSkyLab
                            Toshiba 55SL417U looking for EEPROM and Firmware
                            by NSkyLab
                            Hello everyone, I described the symptoms and measurements here
                            It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
                            I'm not able to find eeprom and firmware dumps in open sources.
                            Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
                            01-20-2023, 12:29 PM
                          • SidneyCanadas
                            93C46 and 93C56 EEPROM
                            by SidneyCanadas
                            I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                            https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                            Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                            06-14-2023, 01:16 PM
                          • wattage
                            AOC AG493UCX 49-inch monitor - Firmware request
                            by wattage
                            Hello Badcaps Community,
                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                            07-13-2025, 04:41 PM
                          • sikocan
                            NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                            by sikocan
                            I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                            However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                            01-11-2024, 01:47 AM
                          • dmccul2698
                            Pioneer DEX-P99rs "No EEProm " diagnostic code.
                            by dmccul2698
                            Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                            1). Understand the schematic and check the connections between the EEProm and DSP
                            2). Check the functionality of the EEProm
                            I don't know if this is the unit's problem but it's a place to start.
                            I have little to no electronic experience...
                            04-08-2024, 05:32 PM
