mytv te32
  • Zac
    • Jan 2020
    • 15
    • Italy
    mytv te32
    hi all, I have a tv that remains fixed in stand-by, sw mp022-jd power supply would seem ok. i think about a firmware problem, the mather board is a cv306h-f. the eeprom memory 25q32fvsic.
    I would need a firmware via usb, or a bios for eeprom. thanks to all greetings zac.
  • lotas
    • Jan 2016
    • 4899
    • Russia
    Re: mytv te32
    Post your non-working firmware dump here, I'll try to fix it.
    • Zac
      • Jan 2020
      • 15
      • Italy
      Re: mytv te32
      thanks for the answer, the discharge from the eeprom? in what format?
      • lotas
        • Jan 2016
        • 4899
        • Russia
        Re: mytv te32
        Originally posted by zac
        thanks for the answer, the discharge from the eeprom? In what format?
        .bin
        • lotas
          • Jan 2016
          • 4899
          • Russia
          Re: mytv te32
          Unsolder 25q32fvsic, read its contents (firmware) on the programmer, save and upload this file in BIN format.
          • Zac
            • Jan 2020
            • 15
            • Italy
            Re: mytv te32
            here I am ... hello LOTAS, sorry for the huge delay.
            • lotas
              • Jan 2016
              • 4899
              • Russia
              Re: mytv te32
              Try it, don't be surprised that the dump size has become smaller.
              • Zac
                • Jan 2020
                • 15
                • Italy
                Re: mytv te32
                hello lotas ...it doesn't open with win.ra ... it tells me damaged archive
                  • 22191
                  Re: mytv te32
                  Update winrar or use 7-zip
                  • lotas
                    • Jan 2016
                    • 4899
                    • Russia
                    Re: mytv te32
                    Update WinRar
                    • Zac
                      • Jan 2020
                      • 15
                      • Italy
                      Re: mytv te32
                      eeprom file working at the first try .. perfect thanks lotas .. the tv had corrupted file, probable forced shutdowns ... question if the same defect occurs again, can I put the .bin file you restored on usb and boot directly from the tv?
                      • Zac
                        • Jan 2020
                        • 15
                        • Italy
                        Re: mytv te32
                        • raileanu
                          • Sep 2015
                          • 128
                          Re: mytv te32
                          Thank you lotas it works perfectly.
                          • karlox
                            Request for EEPROM Firmware Backup – Epson PowerLite S18+
                            by karlox
                            I have an Epson PowerLite S18+ projector in the workshop showing signs of a firmware fault. I’ve checked all voltage lines and signal paths, and everything seems within normal range.
                            Here’s the issue: when the power cable is connected, the power LED immediately turns blue even though the projector doesn’t start. When powered on, the fans run but the lamp never ignites. After a few minutes, both the temperature and lamp indicators turn red.
                            I’m attaching the backup I read from the IC in case it’s useful for analysis or comparison.
                            If anyone...
                            10-16-2025, 07:48 PM
                          • NSkyLab
                            Toshiba 55SL417U looking for EEPROM and Firmware
                            by NSkyLab
                            Hello everyone, I described the symptoms and measurements here
                            It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
                            I'm not able to find eeprom and firmware dumps in open sources.
                            Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
                            01-20-2023, 12:29 PM
                          • zklgfs
                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                            by zklgfs
                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                            08-11-2025, 02:14 PM
                          • SidneyCanadas
                            93C46 and 93C56 EEPROM
                            by SidneyCanadas
                            I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                            https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                            Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                            06-14-2023, 01:16 PM
                          • Slapito
                            Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                            by Slapito
                            I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                            Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                            I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                            I already downloaded the BIOS update file from msi official...
                            10-09-2025, 02:00 AM
