47LW5600 Lines
  • Plurxtc1
    • Oct 2014
    • 136
    47LW5600 Lines
    I have lines on the screen, I have already replaced the T-Con. Do you think replacing the main board could fix it? I got the T-Con from shopjimmy.
  • neilc6
    • Nov 2015
    • 1550
    Re: 47LW5600 Lines
    If you replaced the tcon, more likely a bad panel.
    • lotas
      • Jan 2016
      • 4597
      • Russia
      Re: 47LW5600 Lines
      Was the old T-CON also?
      It looks like RAM or CPU, try to heat up a little CPU with a hairdryer
      • Plurxtc1
        • Oct 2014
        • 136
        Re: 47LW5600 Lines
        Correct there was no change replacing the T-Con
        • lotas
          • Jan 2016
          • 4597
          • Russia
          Re: 47LW5600 Lines
          Something I don't like about your T-con board lack of parts and soldering.
          • alfatv
            • Sep 2020
            • 353
            Re: 47LW5600 Lines
            Main boards are going bad on these
            • lotas
              • Jan 2016
              • 4597
              • Russia
              Re: 47LW5600 Lines
              Yes, on these chassis, the processor suffers from overheating, reballing or replacing the processor helps.
              • neilc6
                • Nov 2015
                • 1550
                Re: 47LW5600 Lines
                LE, LV, LW, and LS have BGA failures. Lots of repair services on ebay if you search.
                Symptoms
                -TV responds to power on command, LED lights run at the front bezel, but the screen never lights up or lights up, but with no image;
                -TV starts up and LG splash screen shows up, but freezes there;
                -TV comes up and has image, but the image or audio is garbled;
                -Loss of HDMI ports or loss of audio.
                • Plurxtc1
                  • Oct 2014
                  • 136
                  Re: 47LW5600 Lines
                  Yeah I did remove some caps because I thought it was short. It wasn't short out of curcuit so I put it back in. But I did order a replacement T-Con it was the same no change.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
                  • Daren87
                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                    by Daren87
                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                    08-13-2023, 03:25 PM
