Re: samsung ue55nu7021k backlights working but blank screen
so, just tried a few things. I can't use the source button on the remote but can change with the buttons on the screen. But like before no sound and it says its optimising the video
seems a common issue just googled the error on no signal screen https://eu.community.samsung.com/t5/...l/td-p/2307700Leave a comment:
Yes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don't know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.Leave a comment:
Well, there are no more options, at your own peril and risk, one way or another, the TV does not work properly.Leave a comment:
so would you still suggest to do a factory reset?Leave a comment:
Yes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don’t know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.Leave a comment:
Trust me im no expert ive learnt all i know from this site and youtube i repair things as a hobby mainly just for myself and family members. we never stop learning.
i have recenty collected a Samsung UE48H6400AW 3d smart tv of a free site it needs new backlight strips just waiting for delivery from china which has been 3 weeks now if tv is ok after i may keep it myself,Leave a comment:
Sorry didn't mean to suggest you're not an expert, to me you are, just that I have no idea! It was a low end tv, but still £400 and expected to last longer than 2.5 years!Leave a comment:
hopefully someone will have seen that failure screen before as i have not, i am still learning about firmware and software issues.Last edited by vinceroger69; 12-06-2021, 11:16 AM.Leave a comment:
i would wait and see what lotas suggestsLeave a comment:
If you reset via the "factory reset" service menu, you will get the TV as if it were from a store.
https://www.wikihow.com/Reset-a-Samsung-TV
Method 5Leave a comment:
try whats suggested in post 19 a factory reset may solve the issues your havingLeave a comment:
Hi, so just started the tv again and the no signal page is not showing properly. Photo of this attached as well as a photo from before when this page was showing properly. I've also attached a photo of the main settings menu which too isn't showing properly. I'll later to see if it displays correctly.
I'm guessing this doesn't help much?Leave a comment:
So I've just tried another software update which is what I assume is a firmware update. I choose as per the photo and then it does something but returns to the main "No Signal" screen again. Checking the software version it's still what it was before.
Also, some options don't seem to be available. Picture attached of some itmes greyed out!Leave a comment:
Sorry I got lost there but assume opening up the back and exposing the motherboard will provide clarity on whats faulty and needs to be replaced?Leave a comment:
I have opened it yet but let me give this a go tonight and I'll get a clear picture. I'm guessing the mainboard will be the large board at back and not the one where the power goes to?Leave a comment:
Thank you for your help and time!Leave a comment:
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
by BloopetaSamsung UE55JU6800K with no image on screen.
I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
by bohabohaHi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
anyhow i couldn't t read anything else
the backlight is on strong and the screen does not get dark or very dark but no pictures
the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
by 4thommoHi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
PSU 17IPS62
MB 17MB110P
Panel VES315WNDS-2D-N144 Photos - Loading...
