Re: samsung ue55nu7021k backlights working but blank screen
so, just tried a few things. I can't use the source button on the remote but can change with the buttons on the screen. But like before no sound and it says its optimising the video
seems a common issue just googled the error on no signal screen https://eu.community.samsung.com/t5/...l/td-p/2307700
Originally posted by lotas View PostYes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don't know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.
Well, there are no more options, at your own peril and risk, one way or another, the TV does not work properly.
so would you still suggest to do a factory reset?
Yes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don’t know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.
Trust me im no expert ive learnt all i know from this site and youtube i repair things as a hobby mainly just for myself and family members. we never stop learning.
i have recenty collected a Samsung UE48H6400AW 3d smart tv of a free site it needs new backlight strips just waiting for delivery from china which has been 3 weeks now if tv is ok after i may keep it myself,
Originally posted by vinceroger69 View Posthopefully someone will have seen that failure screen before as i have not, i am still learning about firmware and software issues.
hopefully someone will have seen that failure screen before as i have not, i am still learning about firmware and software issues.Last edited by vinceroger69; 12-06-2021, 11:16 AM.
i would wait and see what lotas suggests
Originally posted by lotas View PostIf you reset via the "factory reset" service menu, you will get the TV as if it were from a store.
https://www.wikihow.com/Reset-a-Samsung-TV
Method 5
try whats suggested in post 19 a factory reset may solve the issues your having
Originally posted by vinceroger69 View Postwhat is in the general menu?
I'm guessing this doesn't help much?
Method 5
Originally posted by Yoda79 View PostSo I've just tried another software update which is what I assume is a firmware update. I choose as per the photo and then it does something but returns to the main "No Signal" screen again. Checking the software version it's still what it was before.
Also, some options don't seem to be available. Picture attached of some itmes greyed out!
Originally posted by lotas View PostEMMc flash has been used in new models for a long time.
This model also has SPI Flash and EEPROM, but the software is in EMMc.
Originally posted by vinceroger69 View PostNand ic or eeprom ic is the chip that stores the firmware etc on samsungs quite common they go faulty.
Have you got a good clear picture of the mainboard so that we can see all the numbers on it.
Originally posted by lotas View PostThe memory may be full, you can try to do a "factory reset" through the service menu.
Thank you for your help and time!
