Samsung LN46A550P3F C LCD clicking
  • Browns329
    • Aug 2021
    Samsung 46" LCD TV
    Model: LN46A550P3F C
    Model Code: LN46A550P3FXZA
    TV off. Standby light flashing and relay on power supply board clicking every few seconds. Press power button and no change.
    Unplugged main board from power supply board and clicking stopped. Plugged main board into power supply board but unplugged everything else on main board - still clicking.
    Does this indicate a bad main board?
    I don't see any visual signs of bad caps, burns, or cracked solder joints on power or main board.
    Thanks for any tips.
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung LCD clicking
    "A" model years have bad caps (make sure they aren't bulged on the tops) and also a bad C102 cap on the main boards. https://www.badcaps.net/forum/showthread.php?t=45913
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4460
      • Italy - Milan
      indicates that you must begin from the power board, must check it forcing its main stage on.
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • Lee M.
        Samsung UN75RU8000FXZA bad main board?
        by Lee M.
        When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
        11-08-2023, 07:46 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
