Capacitor instead of lamp?
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Hello.
    I have a monitor which has a faulty lamp but I don't have a replacement for it.
    I remember reading a technique on here that you can basically bypass the lamp and disconnect it totally and instead of the lamp you put a capacitor. Does anyone know what im talking about becouse I can't find the thread.
    Or is there any other way I can disable a lamp and instead let the monitor work with just one?
    Board Number EADP-45AF
    Schematic https://www.eserviceinfo.com/downloa...20VS11578.html
    Thanks in advance.
  • petehall347
    • Jan 2015
    • 4439
    Re: Capacitor instead of lamp?
    suppose you could add a working lamp and use it or hide it
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
