Samsung UN70NU6070 TV Issue - HELP!
  • Djgh
    replied
    Re: Samsung UN70NU6070 TV Issue - HELP!
    Another thing I noticed is that when I first turn the tv on, the colors appear to be perfect but slowly goes back to its original color issue
  • Djgh
    replied
    Originally posted by R_J
    Do you have pictures of both t-con boards? it is possible they could be for different models. You can't always go by the BNxx-xxxxxx number you need to use the number on the white sticker. I suspect there is an eeprom on the board and it bight be programmed for a different panel or main board
    Not anymore. Old board is long gone but I purchased the new board based off the sticker on the back.
  • R_J
    replied
  • Djgh
    replied
    People’s faces look like they have a bad tan
  • Djgh
    replied
    Replaced the tcon board. It's definitely better but not perfect, then again I'm comparing it to the picture on my iPhone. It's still a little saturated (maybe that's the word)
  • alfatv
    replied
    Can you go this site and post pictures of gradients white red green blue?
    https://www.eizo.be/monitor-test/
  • dick_barton
    replied
    Originally posted by mmartell
    Probably a gamma issue on the tcon. Think you're on the right track.
    +1
    It does look as though the black level is washed out.
  • mmartell
    replied
  • Djgh
    replied
    It is unlikely to be the backlight, I would first check the source, possible bad hdmi cable? The next thing I would check (reseat) is the LVDS cable between the main board and t-con.
    Ordered a new tcon board so let's see what happens.
    Originally posted by ducky29
    Change the picture settings to vivid or standard. See if that makes any difference.
    Lol thanks for your Input.
  • ducky29
    replied
  • R_J
    replied
  • Djgh
    replied
    Originally posted by alfatv
    Yes, it could be backlight. Did you you run it at 100%?
    In the meantime you can change color temperature setting in user menu and tune white balance in service menu. Reduce backlight to minimum possible setting.
    For best results run the test with fully white screen.
    If white is good, you can play with tint setting for colors, but better set it in the middle.
    Appreciate it the advice. I've played with all the settings, performed a picture and power reset, and even spoke with a Samsung representative. None of those were helpful. I may end up replacing the backlight due to it being inexpensive but was still hoping someone could pinpoint the exact issue.
  • alfatv
    replied
  • Djgh
    started a topic Samsung UN70NU6070 TV Issue - HELP!
    Evening,
    I started experiencing color/brightness issues with my 70” Samsung tv after a year or so from date of purchase. It doesn't seem as bright and the colors are a little off. Is this a backlight issue or something else? I'm pretty hands on, so I don't mind tackling the issue if I can pinpoint what it is.
    Any help would be appreciated.
    Model #: UN70NU6070
    Video comparison:
    https://youtu.be/6dNhwNy_lus
    Last edited by SMDFlea; 07-12-2021, 06:36 AM. Reason: Added UN70NU6070 to thread title
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
    09-07-2024, 05:50 AM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
  • Manucsl
    QE65Q800TATXXC Samsung TV Issue
    by Manucsl
    Hello.
    My TV is a QE65Q800TATXXC Samsung TV.
    Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
    Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
    Any ideas to check would be very appreciated 😊
    After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
    02-19-2025, 07:47 AM
  • FourRunner
    Display issue Samsung TV UA65JS9000W
    by FourRunner
    I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
    10-03-2024, 07:05 PM
