Anyone ever replace an 80 pin surface mount IC successfully?
  • thesteve
    • Jun 2021
    • 27
    The last time I tried, the replacement IC shifted slightly while reheating.
    It was all downhill from there.
    I have a bad HDMI switch IC in an otherwise beautiful 55" Sony.
  • alfatv
    • Sep 2020
    • 353
    Re: Anyone ever replace an 80 pin surface mount IC successfully?
    I would just solder it with fine tip.
    • thesteve
      • Jun 2021
      • 27
      You just reminded me of something I need to buy.
      So I guess the heat gun method is only for removal of the old IC.
      That makes sense... can't go wrong with one pin at a time I guess.
      Although I think I may also need a stereo microscope... this thing is so tiny I have a hard time counting the pins with my magnifying reading glasses.
      https://www.semiconductorstore.com/p...SiI9287_DB.pdf
      • mmartell
        • Oct 2013
        • 3189
        A stereo microscope WILL make your life easier for this kind of stuff. I just replaced a 144 pin ADV7623 HDMI switch in a Marantz receiver with one. Would have been impossible for me without it.
        • alfatv
          • Sep 2020
          • 353
          I managed to do much tougher job with iPhone
          https://www.badcaps.net/forum/showthread.php?t=95234
          But looking for holder suggestions.
          iPhone is OK for occasional use at home, but I agree that microscope is the right tool to do things properly.
          • thesteve
            • Jun 2021
            • 27
            Yeah, I ruined a very nice Denon receiver trying to replace a similar chip. Time I got the right tools. A few traces disappeared... I guess it's still possible to fix.
            This sounds like a plan. Maybe I can even fix my old iPhone 5 that I messed up while replacing the battery. They put some tiny surface mount transistors right in the first place anyone would think to pry the battery out. It still works but no home button or power switch.
            For the record, when I was in my 20's back in 1993 or so I successfully replaced a similar microprocessor with just a Weller and my younger eyes. : )
            edit: oh I see what you meant. I only recently discovered my iPhone's magnifier feature. Comes in handy.
            • Yarecky3
              • Mar 2023
              • Ireland
              I would suggest to get any microscope. I jused to solder Motorolas processors for years without it and can say its possible. But once i got some vintage microscope with removabke multiplier eye magnifying things its make me life so easier and no stressful.
                • 12128
                • U.S.
                One method there: https://www.youtube.com/watch?v=QiIy3Oe2UGI
                • fanaticgames
                  • May 2017
                  • 138
                  • italy
                  you must already have previous experience in this type of soldering I personally use hot air to desolder it and also to solder the new one but at 99% all the pins never solder so you will have to go over with a fine tip soldering iron, the things you need to keep in mind they are quality tin and quality flux and obviously you have to get a microscope otherwise it is impossible
                  • thesteve
                    • Jun 2021
                    • 27
                    Good information. I did use a heat gun. I forget the details of what went wrong, as this was a while ago, but I appreciate the tips.
                    I'm happy to say I finally found the right replacement board for the Sony TV.
                    I use the Denon for music only.
                    So I guess all is right with the world.
                    Thanks.
                      • 12128
                      • U.S.
                      It's like any skill, it just needs to be practiced, use scrap boards for learning, hot air or fine tip, even using the solder braid needs practice.
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                        Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-06-2024, 08:10 PM
                        Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                        This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
