Sony Firmware update interrupted early? Now what. KDL55EX-720
  • thesteve
    • Jun 2021
    • 27
    Hi, apologies for another post but as I figure things out I have entirely different questions.
    I'm pretty sure I prematurely interrupted my firmware update. This was done "blindly" from a USB drive with no display (after replacing the B* board).
    Now when I plug it in I get the dual blinking amber and green lights like before, but there is no USB activity at any time.
    After a minute or so, the dual blinking amber and green lights stop and I get a solid red light, followed eventually by 8 red flashes (software error).
    It's a shame because I know the upgrade process was working because after finally getting the right .bin file and the sequence right, I could see it reading the USB drive for many seconds like it was really working. Plus there were all sorts of cool patterns going on with the lights for a long time like it was working.
    Is there a way to restart the firmware flash process ? or am I screwed.
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • rumpumpel1
    ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
    by rumpumpel1
    Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
    10-24-2024, 08:59 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
  • piernov
    Infineon TPM firmware update files
    by piernov
    Infineon TPM firmware update files:
    Infineon_firmware_update.zip
    Code:
    TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
    TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
    TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
    TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
    TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
    10-25-2025, 10:09 AM
  • Thomas Dunlap
    Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
    by Thomas Dunlap
    I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
    The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
    My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
    09-26-2025, 12:45 PM
