Slight backlight problem after replacing main AV card on LG 65UB680
  • marekk
    • Mar 2013
    • 36
    I was struggling to find replacement of the main AV card for 65" LED LG TV 65UB680 and finally I have purchased main board for 79" model 79UB680.
    Board does fit and works except slight problem with backilight at startup where two bit darker bands are visible. As soon as picture is displayed fault is not visible. I believe that such fault is caused by different firmware design for bigger screen.
    Could you let me know how to access service menu on that model to change screen size?
    I have tried common metods like "Press and hold <OK> buttons on remote as well as TV panel for a few seconds" and none of them worked for me.
    Do I need service remote?
    I will appreciate a lot any help.
    https://ibb.co/S7F2KcL
    https://ibb.co/zJCD0xJ
  • neilc6
    • Nov 2015
    • 1550
    Re: Slight backlight problem after replacing main AV card on LG 65UB680
    You need a LG service remote to enter service menu or a cellphone with IR and an app that can send the "INSTART" command.
    • Rofix
      Problem HP Main Board DAG3DCMBCC0 REV C
      by Rofix
      Hello everyone I wanted to kindly ask you for advice I have a problem with this HP Main Board DAG3DCMBCC0 REV C motherboard, the PC does not turn on, the power connector works, 19V arrives, on the first three mosfets there are 19V, the main voltages such as 3.3V and 5V are on the various coils, on the power button 3.3V arrives, I checked the power button and it works, but the PC does not turn on, moreover when I connect the power supply to charge the battery it does not charge, no LED lights up at the moment as the voltage is at 14.7V, the nominal voltage written on the battery is 15.4V, I also...
      12-19-2024, 02:10 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • GardevoirForEver
      Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
      by GardevoirForEver
      I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
      Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
      The motherboard of my ASUS...
      11-15-2025, 04:30 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
