LG OLED 55EC930T Off after a few seconds
  • dvadssc
    • May 2023
    • 17
    • Sri Lanka
    Re: LG OLED 55EC930T Off after a few seconds
    Originally posted by Diah
    when Module pulling over current because of burned cells. it will trick sos signal from T-CON to MB and from PSU to MB.. depending on the model type.
    my post #17 only the answer i can give to you.
    So you think that there's no issue with the main board?
    If I manage to isolate the SOS signal I may be able to get the set into working state?
    in order to isolate the SOS signal what do you propose I do.
    Your continued help is greatly appreciated.
    • dvadssc
      • May 2023
      • 17
      • Sri Lanka
      yes its panel burned... you can isolate the SOS signal between T-CON and MB to remain on.... in this case the TV had function pixel refresh who knows could be work for long time as now its rubbish
      Dear Diah,
      As you have suggested and the details available on thread "LG 55EA970V OLED / black screen" I have traced the path from MICOM pin 16 to the TCON connector and it was observed that MICOM pin 16 is connected to TCON connector PIN 12 for SOS signal as it was traced back from the MICOM.
      Do you think it's the right SOS signal path?
      Best Regards
      Dulaj
      • Diah
        • Feb 2013
        • 6368
        i don't have documentation on micom chip ...terminate the line so you will know... if the micom didn't start mean after termination the sos the pin 16 need to be low
        • dvadssc
          • May 2023
          • 17
          • Sri Lanka
          Dear Diah,
          Sorry to bother you after a while.
          I was waiting for a new service remote from China. The exit button of the previous one was not working properly Therefore, I was unable to properly exit the power only mode.
          Now that the new SVC remocon is available I have plugged in all boards and started the unit in power only mode and exited the power only mode. Unlike before the LG LED is remaining on.
          What do you prefer I do next?
          Always grateful for your continued support.
          • dvadssc
            • May 2023
            • 17
            • Sri Lanka
            Originally posted by dvadssc
            Dear Diah,
            Attaching the image of power only mode
            • dvadssc
              • May 2023
              • 17
              • Sri Lanka
              #26
              Dear Diah,
              Found the schematics related to the MB. It seems that the panel burnt detection signal is coming through PIN 12 of the LVDS connector to the motherboard MICOM pin 16. Tested the voltage level of the pin and when the TV is powered on the pin voltage only rises to 0.4V and then shuts down. To confirm, the path between the LVDS pin 12 and micon pin 16 was removed and tested. Still the relay clicks off.
              Therefore we can assume that the reason for the TV clicking off is not the panel burnt issue but something else. Do you have any insights on this.
              Regards, Dulaj.
              • Diah
                • Feb 2013
                • 6368
                Dear Diah,
                Regards, Dulaj.
                you have panel fault. no other reason
                one things more.. over all error circuit signal. if its OLED Panel or LED error on LCD LED TV, the by pass only the error when the pins go to GND.
                becarfull by passing OLED Panel error could caused fire on the screen... real fire and we saw many over here too.
                • Diah
                  • Feb 2013
                  • 6368
                  after you isolated pin12 on LVDS.... did you bridge MICOM pin 16 via 1K/R to GND !!!
                  • alltvrepairs
                    Lg TCon test pins for screen test
                    by alltvrepairs
                    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                    Appreciate your help....
                    06-13-2025, 06:33 AM
                  • odie34
                    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                    by odie34
                    I am a hobbyist (not a professional) so please be gentle...
                    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                    02-18-2024, 09:11 AM
                    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 04:30 AM
                    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 07:12 AM
                    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
