LG OLED 55EC930T Off after a few seconds
  • Davo291
    • Jun 2021
    • 3
    I join a long line of posts with a similar issue but have a slight difference, so I am seeking definitive advice to give up, as the screen is dead or not as it maybe a board.
    Rather than go into all the detail, as I have read and followed a lot of the posts and this issue - especially from Diah. I will summarize,
    I have proven all the PS voltages via the globe test (12v 55/60W globe)
    I have connected the unplugged T-Con board to 12V and 24V after linking Power on and Driver on to 3.5V. This test starts a cyclic black, red, green, blue, white screen display. The difference I have to other posts is that only a portion of the screen is always black and I have a good full width band across the bottom. This test ran for 45mins with nothing getting hot.
    This looks to me like an addressing error (missing a significant bit) rather than a shorted OLED cell - I'm assuming the cell addressing is a function of the T-Con.
    See images, noting the moiré pattern on white is not visible to the eye.
    Main symptom, with everything plugged in, is turn off after a few seconds (same as most other posts on LG OLED55EC930*)
    I haven't tried any reset processes as yet as I don't have an IR device only have the magic remote. I also don't have an oscilloscope as mine blew up after not using it enough (gassy CRT)
  • Diah
    • Feb 2013
    • 6380
    Re: LG OLED 55EC930T Off after a few seconds
    because you summarize my test guides so i am answering you over here and will be my last one over the forum.
    yours issue could be 2
    the first are bad OLED muddle
    the second bad ribbon ( burn ) or BGA at t-con ( this less happened )
    on both reasons you can have linted function on this tv by bypass the micom IC3000 on main boards to low on 24v sync pins.. the SMPS test PDF of this set am sure you downloaded over this forum explain which pins.
    good luck and keep all healthy.
    bye
    • Davo291
      • Jun 2021
      • 3
      Thanks Diah
      I was able to progress troubleshooting by setting up an IR remote android and setting In-Stop. This enabled the set to start and I had a tv picture and sound for a short time. The TV image covered the full screen, however was faded with random horizontal noise in the same area visualized in the red, green, blue test (See attached). After a short time the set turned off and returned to the switch off after a few seconds sequence. This definitely eliminated the main board as the cause of the issue.
      No matter what I tried I could not again reset the fault mode via In-Stop.
      Continuing with the T-Con and back to the test RGB setup,
      I swapped around the ribbon cables to different positions
      I tried to mechanically and thermally affect the BGA components of the T-Con but nothing changed the image.
      I'll assume that the issue is with some inaccessible component of the OLED panel as I think it will be a waste of money to get a dubious quality T-Con board off eBay. Time to give up an contribute more 1st world junk to the environment. Thanks LG - it worked great for 5 whole years.
      Happy for anyone else to convince me it would be a good idea to try changing the T-Con.
      • dvadssc
        • May 2023
        • 17
        • Sri Lanka
        I'm a new guy here.
        Got a dumped LG 55EC930T due to non-switching on issue.
        When the set is powered up with 230V and switched on with the power button, the LG logo lights up with the relay clicking and fades away after 3 seconds with the relay clicking.
        As recommended in the other threads, the set was opened up and the SMPS test was conducted. SMPS test passed without any issues. Then the main board was removed, and the T-CON was rigged to get in to the RGB panel test mode where the solid Red, Green, Blue, and white screens are produced (Attachments A, B, C, D, E). Then the Main board was refixed, and the connectors were fixed in place and set was switched on again. Still the same issue persists.
        Then the set was switched on with the Service remote with power only button and the white screen (Attachment F) is appeared and goes off after 10 seconds. attached the pictures. What should be my next move in identifying the fault of the TV set.
        During these 10 seconds the IC (Attachment G) indicated on the main board heats up a lot.
        Thanks in advance.
        BR
        Dulaj
        • Diah
          • Feb 2013
          • 6380
          Originally posted by dvadssc
          I'm a new guy here.
          try to insert USB stick on it root mpeg (video ) film, and on other usb port USB mouse or air mouse.... then turn on and start play with mouse... hope yours MB will wake up
          • dvadssc
            • May 2023
            • 17
            • Sri Lanka
            Thanks Diah,
            Tried as you suggested. powered up with a USB stick plugged in with mpeg and tried using a USB mouse simultaneously. Still the same.
            When powered up with the usual power on button the set clicks off in 3 seconds during which the USB mouse keep lit.
            When powered up with power only same white screen above appears and shuts down after few seconds. During the service power only command USB mouse does not light up.
            Any other tests you want me to try out?
            Many Thanks,
            Dulaj
            • Diah
              • Feb 2013
              • 6380
              Thanks Diah,
              Many Thanks,
              Dulaj
              during power only try to exit this mode before it turn off.
              and do again the stand alone test for panel and t-con long time to be sure there are no burn in cells
              • dvadssc
                • May 2023
                • 17
                • Sri Lanka
                Dear Diah,
                Did exactly as you suggested. found some dead pixels on the white screen (attached picture) and put it to regenerate. How long do you want me to keep it running? what do you suggest I do after that.
                Thanks again for your immense support.
                Regard
                Dulaj
                • Diah
                  • Feb 2013
                  • 6380
                  keep it on.. for at least 1 hour... and with yours finger click on the area smoothly to notice any change... but be caution . it may get fire at this burned place
                  • Diah
                    • Feb 2013
                    • 6380
                    BTW. did you removed the ribbon cable on this area between T-CON and module ?
                    in case you did before... then need to inspect the pins contact of the ribbon cable if there any where shortness or moved to side
                    • dvadssc
                      • May 2023
                      • 17
                      • Sri Lanka
                      Dear Diah,
                      I have kept it on for about an hour now. The panel seems okay now. No flickering or dead pixels observed now. Shall I keep it like this for some more time or what should I do next?
                      Regards,
                      Dulaj
                      • Diah
                        • Feb 2013
                        • 6380
                        Dear Diah,
                        Regards,
                        Dulaj
                        read my last post.... and this color should be real white not such color..
                        • dvadssc
                          • May 2023
                          • 17
                          • Sri Lanka
                          Yes I have removed the ribbons from T-CON to display and T-CON to main board. I have checked for any short or defected connections before connecting back and found no observable issue.
                          • dvadssc
                            • May 2023
                            • 17
                            • Sri Lanka
                            It is pure white. The phone camera doesn't capture it properly due to the change of screens in a rapid succession.
                            • Diah
                              • Feb 2013
                              • 6380
                              then you have sos signal.. see the other threat of today where we were talking on micom pin 16
                              • dvadssc
                                • May 2023
                                • 17
                                • Sri Lanka
                                Diah,
                                I think the issue is with the panel. When the set is switched off and switched on again the initial black display came on like this.
                                • Diah
                                  • Feb 2013
                                  • 6380
                                  Diah,
                                  yes its panel burned... you can isolate the SOS signal between T-CON and MB to remain on.... in this case the TV had function pixel refresh who knows could be work for long time as now its rubbish
                                  • dvadssc
                                    • May 2023
                                    • 17
                                    • Sri Lanka
                                    Thanks for all your support Diah. Ill try your method to isolate the SOS signal and try to get it functioning again.
                                    • dvadssc
                                      • May 2023
                                      • 17
                                      • Sri Lanka
                                      Sorry to bother you again Diah,
                                      Kept the display running for several hours and the display issue is not present anymore. Also done some on /off cycles of the display pattern and no any observable issue identified. attached a video zip file also.
                                      Still when switching on using the remote relay clicks off in few seconds. and even though tried to wake using the mouse and no luck.
                                      Is it may be the main board faulty
                                      Best Regards,
                                      Dulaj
                                      • Diah
                                        • Feb 2013
                                        • 6380
                                        when Module pulling over current because of burned cells. it will trick sos signal from T-CON to MB and from PSU to MB.. depending on the model type.
                                        my post #17 only the answer i can give to you.
                                        • alltvrepairs
                                          Lg TCon test pins for screen test
                                          by alltvrepairs
                                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                          Appreciate your help....
                                          06-13-2025, 06:33 AM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
