Help with mosfet selection for TCL power supply
+ More Options
Posts
  • cook
    Quiet observer
    • May 2010
    • 100
    I am working on a TCL 55s405. I am strictly a novice at electronic repairs.
    I have a bad mosfet on the hot side of the power supply board. It is an ap50wn1k0h, and the specs. of it are below.
    Will the aod9n50 mosfet be a good replacement for it? Its specs. are below too.
    I selected this one because I could not easily find a 7 amp mosfet to replace the bad one, so I went with the next higher amp one I could find that seemed to be close.
    Thank you so much.
  • cook
    Quiet observer
    • May 2010
    • 100
    Re: Help with mosfet selection for TCL power supply
    Perhaps I have posted this in the wrong forum... Should I move this to the Power Supply forum? (And also add the model number to the title.)
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      On a quick glance it does appears to be suitable
      AP50WN1K0H 500V, 1.03 ohms, 7A, VGS +/- 30V, 83W
      AOD9N50 500V, 0.8 ohms, 9A, VGS +/- 30V, 175W
      • cook
        Quiet observer
        • May 2010
        • 100
        Thank you Dick-Barton.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
