sony Bravia KLV-40S400A pic goes off and on
  • provider10
    • Mar 2016
    • 52
    • South Africa
    hi
    Goy this Sony Bravia KLV-40S400A
    On switch on the picture comes up for 7 seconds Then goes off for about 10 Seconds, with a click of a relay. This keeps going on and off ad infinitum. When it goes off the backlights also go of.
    Havent worked on many Sony's so I am a bit lost
    Any help would be appreciated
    James
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: sony Bravia KLV-40S400A pic goes off and on
    Can you turn the backlights down and see if it stays on longer before going off again If it does then you may have issues with one or more of the leds.
    • provider10
      • Mar 2016
      • 52
      • South Africa
      Hi
      A bit of a problem the set doesnt stay on long enough to get into the menu
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • PopsCaps
        Sony Bravia KDL-40V2500 that will not power on
        by PopsCaps
        I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
        I do not hear any sound and I cannot see any backlight.
        I have tried disconnecting every cable on each board one at a time to see if anything changes.
        The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
        My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
        03-25-2025, 11:23 AM
      • alegatorul
        sony bravia kdl-43w756c, no power, no sound
        by alegatorul
        the charger brick has 19,2-19,3 vcc
        changed the inverter board same result.
        where should i start?
        cheers
        11-15-2025, 10:00 AM
      • justin35
        Sony bravia kdl-43w755c - boot loop
        by justin35
        i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
        from what i read online it looks to be an emmc issue…
        i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
        i took out the board and say an samsung 16gb emmc
        i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
        i could try to put one instead of the 16gb one, but will it work?
        where do i get the software from?
        any help will be much appreciated!...
        03-06-2024, 12:26 PM
        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
        Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
        10-16-2024, 05:15 AM
